Upgrading Memory on 871W
marlzzzzz
I want to upgrade my IOS on an 871W.  In order to do this I need to upgrade the memory.  I have found that I need the MEM870-32F  (Am I correct?).
As in here:  http://www.ebay.com/itm/MEM870-32F-32MB-FLASH-MEMORY-CISCO-871-871W-876-877-878-/160618055561?pt=COMP_EN_Networking_Components&hash=item2565950789#ht_500wt_1180
So if I follow these instructions:
http://www.cisco.com/en/US/docs/routers/access/800/hardware/notes/800upgrd.html
Is that all there is to it?
Thanks for any advice you can give me!
Leo Laohoo
Yup.  This will upgrade your Flash from 24 to 32 meg.  This module will NOT upgrade your DRAM.
Don't forget to use the static discharge strap to prevent you frying the memory.
