Issue with ADSL /PPPoE over a 1-WIC-ADSL
Francis Garcia
Dear all,
I am having a little hard time configuring a PPPoE because the provider is using 2 PVC for the connection. I attached the pic taken from the modem where the service was configured. What I want is to change the modem for the ADSL-WIC and to use it as PPPoE client.1.bmp
Francis.
Giuseppe Larosa
Hello Francis,
ot be honest this looks like a picture taken from a lab book, however you have a trouble to solve.
ATM is based on PVCs made of VPI and VCI fields in ATM cell header.
Now, the router is a DTE connected to the ATM cloud with its own interface.
All you need is to map each PVC to a different p2p subif and voilà you have achieved your goal
int atm x/y/z
no ip address
int atm x/y/z.35 point-to-point
description associated to a PPPoEoA session uses aal5mux it may invoke a virtual template
pvc 8/35
encapsulation aal5mux .......
int atm x/y/z.39 point-to-point
desc classical IPv4 over ATM  = using AAL5 SNAP
ip address 192.168.2.1 255.255.255.252
pvc 1/39
encapsulation aal5snap
protocol ip 192.168.2.2 broadcast
I think you can easily fill the holes now with the whole picture
notes:
think of protocol command and of the broadcast option, why and when they are needed?
ATM command reference can answer to this.
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello Francis,
int atm x/y/z
no ip address
pvc 8/35
pvc 1/39
notes:
Hope to help
Giuseppe
Hi Giuseppe,
My relevant configuration looks like this.
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
interface ATM0/1/0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
interface ATM0/1/0.39 point-to-point
ip address 192.168.2.1 255.255.255.0
pvc 1/39
interface Dialer1
mtu 1472
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap
ppp pap sent-username xxx@xxxx password 7 #$%SDFGY
We have a 7 publics ip subnet, but what happens is I am not able to ping the atm pvc even when it appear to be up. I don't know what I am doing wrong.
router_scz#ping atm interface atm 0/1/0.39 1 39
Sending 5, 53-byte end-to-end OAM echoes, timeout is 2 seconds:
Success rate is 0 percent (0/5)
router_scz#ping atm interface atm 0/1/0.1 8 35
Francis
Default Gateway?? check show atm pvc X command for check oam received and oam sended for problem in your ISP...
Hi Victor,
Nothing, no OAM cells received or sent. I have the default gateway configured as the service provider and doesn't respond. Here I send the output of the command and a print screen of the modem configuration.
router_scz#show atm pvc 1/39
Description: N/A
ATM0/1/0.39: VCD: 2, VPI: 1, VCI: 39
UBR, PeakRate: 32 (76 cps)
AAL5-LLC/SNAP, etype:0x0, Flags: 0x1840, VCmode: 0x0, Encapsize: 12
OAM frequency: 0 second(s), OAM retry frequency: 1 second(s)
OAM up retry count: 3, OAM down retry count: 5
OAM END CC Activate retry count: 3, OAM END CC Deactivate retry count: 3
OAM END CC retry frequency: 30 second(s),
OAM SEGMENT CC Activate retry count: 3, OAM SEGMENT CC Deactivate retry count: 3
OAM SEGMENT CC retry frequency: 30 second(s),
OAM Loopback status: OAM Disabled
OAM VC Status: Not Managed
OAM Loop detection: Disabled
ILMI VC status: Not Managed
InARP frequency: 15 minutes(s)
InPkts: 0, OutPkts: 39, InBytes: 0, OutBytes: 3587
InPRoc: 0, OutPRoc: 17, Broadcasts: 22
InFast: 0, OutFast: 39, InAS: 0, OutAS: 0
InPktDrops: 0, OutPktDrops: 0/0/0 (holdq/outputq/total)
CrcErrors: 0, SarTimeOuts: 0, OverSizedSDUs: 0, LengthViolation: 0, CPIErrors: 0
Out CLP=1 Pkts: 0
OAM cells received: 0
F5 InEndloop: 0, F5 InSegloop: 0,
F5 InEndcc: 0, F5 InSegcc: 0, F5 InAIS: 0, F5 InRDI: 0
OAM cells sent: 0
F5 OutEndloop: 0, F5 OutSegloop: 0,
F5 OutEndcc: 0, F5 OutSegcc: 0, F5 OutAIS: 0, F5 OutRDI: 0
OAM cell drops: 0
Status: UP
VC 1/39 doesn't exist on 1 of 2 ATM interface(s)
Francis
Hi Giuseppe,
I solve the issue assigning the ip addresss statically into the dialer interface, for some reason the provider is not
assigning it automatically by DHCP, but anyways It is working fine now using the router as CPE. Thank you very much the information you gave me, It was pretty helpful. I told you I was a little confused about the 2 pvc because I have never seen any provider using PPPoE with two pvc.
About the picture It was a print screen from the modem itselft, and I was ussing Ms-paint to modify only the relevant information. This is for protecting the ip address block. Now I know that you can help me once in a while wih my labs .
Here I paste the relevant configuration that worked for me and can work for someone else.
pvc 8/35
pvc 1/39
interface Dialer1
mtu 1472
ip address X.X.X.X X.X.X.X
encapsulation ppp
no ip route-cache cef
no ip route-cache
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname XXXX@domain
ppp chap password  ZZZ
ppp pap sent-username YYYY@domain password ZZZ
ppp ipcp dns request
ip route 0.0.0.0 0.0.0.0 dialer 1
Francis
