11-24-2014 07:44 AM - edited 03-05-2019 12:13 AM
Good Morning,
I recently purchased 3 Cisco Catalysts Switches 2960XR-48LPD-I
I realized that I should have purchased instead 3 2960XR-48FPD-I. But it is too late. I cannot return the switches to Amazon after 3 months purchase
Is it possible to remove the 640 W AC Power Supply of the Switches 2960XR-48LPD-I and replace them with 1025 Watts Power Supply
in order to upgrade the PoE Power of the Switches 2960XR-48LPD-I from 370 Watts from 740 Watts.
Your Help and Response will be appreciated
11-24-2014 02:21 PM
I do not think it is possible to upgrade the power supply of the 2960X/XR without breaking the warranty. See image below.
11-24-2014 02:50 PM
The Power Supply PWR-C2-1025WAC is a FRU type (Field Replacement Unit) as well as the 640 Watts the equiment came with:PWR-C2-640WAC.
It should not void the warranty. The thing is, I cannot find the data sheet for the PWR-C2-1025WAC
Can someone help?
11-24-2014 03:44 PM
My apologies. I misread your post.
Yes, the PS for the XR are field replaceable. I haven't tried replacing the LPD with a 740w PS will make it support 48-ports PoE.
11-24-2014 09:00 PM
Answer:-NO.
The Catalyst 2960XR-48FPD-I and 2960XR-48FPS-I only support thePWR-C2-1025WAC powersupply.
You can get more info on the following:
Catalyst 2960-X and 2960-XR Switch Hardware Installation Guide
Inayath
11-26-2014 09:02 AM
Good Afternoon,
Thank you for your shedding some light. But there is something misleading though. If you google "compatibility PWR-C2-1025WAC", you will see a list where they show the Switch CS-2960XR-48LPD-I as being compatible with the 1025 Watts AC Power supply. You might want to check the following website among many other websites, for compatibility information. :
http://www.zones.com/site/product/index.html?id=100660859&page_name=product_tech_spec
So why do they show the CS-2960XR-48LPD-I as being compatible to the PWR-C2-1025WAC Power Supply? Your Response will be appreciated
06-13-2018 03:12 AM
i know that your post is now a long time ago. But i'm currently in the same Situation.
Did you managed to replace the WS-C2960XR-48LPD-L PSU to PWR-C2-1025WAC ?
And did the Switch now support more PoE Power ?
Would be great if you had a answer for me.
Best Regards
Matthisa
