Upgrading the hub router in a DMVPN
CiscoMedMed
I have a pair of 3945 routers that are proving to be underpowered for the 100+ remote offices connecting to them. Fortunately I happen to have a couple of 4351 ISRs rated for significantly greater encrypted throughput. Is there any way I could upgrade the primary hub of the DMVPN without doing a new certificate request from each spoke? Any other considerations on upgrading the hub and
You don't need to replace the spoke certificates, you just need to ensure the Hub has a certificate that is trusted by the spokes. Either generate a CSR and issue a new certificate to the new Hub from the same CA that is currently used or export the existing Hub's certificate and import to the new Hub.
