Uploading configuration files to MGX8850
moelsaye
Hello all,
I need to upload customer configuration files to MGX8850. I am new to the WAN switching and I need a good link that help me upload the configuration files from a FTP or TFTP?
Also I need some a good link to IMA on the MGXs. Thank you very much for your help.
Mo
mohammedmahmoud
Level 11
Level 11
Which firmware release are you using.
BR,
Mohammed Mahmoud.
Hello Mohammed,
The boot firmware revision for the PXM45B is 5.2(10.201)
Thx.
Mohamed
Hi Mohamed,
You'll find in this document everything related to AUSM and IMA:
http://www.cisco.com/univercd/cc/td/doc/product/wanbu/8850px45/rel52/ausm/index.htm
As for restoring the configuration for the whole MGX use the following steps (if you are talking about a single customer configuration you must do it manually or via CWM):
Restore the configuration file from the CWM (or the backup server) via tftp.
Use tftp put command on the CWM to the CNF folder of the MGX (ex: CNF/.zip)
start to restore the configurations using "restoreallcnf -f "
http://www.cisco.com/en/US/products/hw/switches/ps1938/products_configuration_guide_chapter09186a00800dff26_4container_ccmigration_09186a00801e88fa.html#1126325
You'll find all the relevant documents for MGX 8850 PXM45 in this url:
http://www.cisco.com/univercd/cc/td/doc/product/wanbu/8850px45/rel52/index.htm
HTH,
Mohammed Mahmoud.
