How would I limit email with Qos?
jerry.mcrae
i want to test the effect of limiting our email (exchange) traffic to a certain amount of bandwidth to allow for a better flow of voip traffic. i currently have qos in place but i still have some voice issues . i know our qos policy is working but i need to tone down email. i think it's b/c we pass a ton of email traffic through 3 t-1's along with voice traffic.
so i was thinking of creating an acl for email then giving it some where around 300 - 500 k per t-1 and adding it to the current qos config.
class-map match-all voice-signaling
match ip dscp af31
class-map match-any voice-traffic
match ip dscp ef
match ip rtp 16384 16383
policy-map EWT_SP
class voice-traffic
priority 800
class voice-signaling
bandwidth 8
class class-default
fair-queue
sh policy-map EWT_SP
Policy Map EWT_SP
Class voice-traffic
Strict Priority
Bandwidth 1042 (kbps) Burst 26050 (Bytes)
Class voice-signaling
Bandwidth 8 (kbps) Max Threshold 64 (packets)
Class class-default
Flow based Fair Queueing
Bandwidth 0 (kbps) Max Threshold 64 (packets)
EWT_NOC#sh policy-map int ser4/0:0
Serial4/0:0
Service-policy output: EWT_SP
Class-map: voice-traffic (match-any)
2148676 packets, 136995992 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: ip dscp ef (46)
967403 packets, 61480518 bytes
30 second rate 0 bps
Match: ip rtp 16384 16383
1181273 packets, 75515474 bytes
Queueing
Strict Priority
Output Queue: Conversation 264
(pkts matched/bytes matched) 772408/19968407
(total drops/bytes drops) 0/0
Class-map: voice-signaling (match-all)
2604 packets, 320684 bytes
Match: ip dscp af31 (26)
Queueing
Output Queue: Conversation 265
(pkts matched/bytes matched) 2604/320684
(depth/total drops/no-buffer drops) 0/0/0
Class-map: class-default (match-any)
70045641 packets, 16140010608 bytes
30 second offered rate 414000 bps, drop rate 8000 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 25/21976/0
6 Replies 6
Joseph W. Doherty
Depending on IOS version, you would define a class for you e-mail and activate a shaper or policier.
PS:
Seeing
and
while other class rate show zero rates, how much bandwidth is available on this link?
If the link's full bandwidth is small enough, your solution might be via LFI.
while other class rate show zero rates, how much bandwidth is available on this link? this is a HDLC t-1.
If the link's full bandwidth is small enough, your solution might be via LFI. the circuit is a full t-1.
i'll look into shaping.
thanks.
Ok, for a full T-1, you shouldn't need LFI.
Unless you didn't post parts of your outbound policy stats, the stats seem off for a full T. Have you seen the interface's stats hit about 1.5 Mbps?
if you mean do the ser int peak at nearly 100% - yes it can some times. i included the " sh policy-map int ser4/0:0" and sh in ser4/0:0.
Serial4/0:0
2242510 packets, 142964898 bytes
981198 packets, 62335478 bytes
1261312 packets, 80629420 bytes
Queueing
Strict Priority
(pkts matched/bytes matched) 812584/21020804
2734 packets, 336920 bytes
Queueing
(pkts matched/bytes matched) 2734/336920
79607911 packets, 25344098513 bytes
30 second offered rate 1244000 bps, drop rate 0 bps
Match: any
Queueing
(total queued/total drops/no-buffer drops) 0/22405/0
EWT_NOC#sh int ser4/0:0
Serial4/0:0 is up, line protocol is up
Hardware is DSCC4 Serial
Description: Second T1 to 7204 on Channel 11
Interface is unnumbered. Using address of FastEthernet0/0.10 (172.16.1.1)
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 117/255, rxload 13/255
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:03, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 22405
Queueing strategy: Class-based queueing
Output queue: 13/1000/64/22405 (size/max total/threshold/drops)
Conversations 2/66/256 (active/max active/max total)
Reserved Conversations 1/1 (allocated/max allocated)
Available Bandwidth 108 kilobits/sec
30 second input rate 81000 bits/sec, 73 packets/sec
30 second output rate 709000 bits/sec, 109 packets/sec
33191015 packets input, 2102745354 bytes, 0 no buffer
Received 64818 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
81839207 packets output, 3906379027 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
1 carrier transitions
Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags
Other than the interface showing "30 second output rate 709000 bits/sec" and the policy showing "30 second offered rate 1244000 bps, drop rate 0 bps", these don't show drops at 400 Kbps.
For a fast test, to see whether shaping or policing provides the benefit you seek, you could try the shaping or policing in the default class.
thanks i'll look into shaping.
