01-19-2023 07:54 AM
Hi.
In a default EIGRP configuration, when a new VPN tunnel is created, does EIGRP automatically distribute this new locally connected route?
Thank you.
Solved! Go to Solution.
01-19-2023
11:36 AM
- last edited on
01-23-2023
01:16 AM
by
Translator
No,
Except case
thar eigrp net
command cover the vpn pool subnet, then when vpn up the eigrp will advertise vpn ip to lan.
01-19-2023
03:21 PM
- last edited on
01-23-2023
01:18 AM
by
Translator
By Default EIGRP does not advertise any networks to anything. You need to configure what interfaces you want explicitly to participate in EIGRP, to include your VPN networks.
You can do this with a
network command
or a
redistribute command
If in the case you mean a tunnel interface make sure you dont advertise the tunnel interface IP/network and the interfaces associated with it both in EIGRP or you'll end up with recursive routing and it will bring the tunnel down.
If you want to avoid that I would create a static route for the physical interfaces to eachother and advertise the tunnel interfaces in EIGRP.
Hope that helps
-David
01-19-2023
10:36 AM
- last edited on
01-23-2023
01:13 AM
by
Translator
if the
static routes
are not redistributed, then NO i guess (high level) - we need to look what configured on your side.
01-19-2023 10:50 AM
Yes, if you config redistrubte connect then any vpn local subnet will redistrubte into eigrp.
01-19-2023 11:03 AM
"Yes, if you config redistrubte connect then any vpn local subnet will redistrubte into eigrp."
if there is implemented the simple default EIGRP services, will the rout be identified and then propagated through the LAN?
01-19-2023
11:36 AM
- last edited on
01-23-2023
01:16 AM
by
Translator
No,
Except case
thar eigrp net
01-19-2023
03:21 PM
- last edited on
01-23-2023
01:18 AM
by
Translator
network command
or a
Hope that helps
-David
01-19-2023
09:44 PM
- last edited on
01-23-2023
01:22 AM
by
Translator
The original post refers to a default eigrp configuration. I am not sure what that means.
To be able to give good advice we need more information. The best would be to post the complete current running config (with sensitive information disguised). If you do not want to give that then at least we need the output of the commands
show ip interface brief show run | section eigrp
