[URGENT] ASA cannot recieve 443 connections - AnyConnect Portal
secretAlpaca
Cisco ASA 5520 is throwing this error whenever someone tries to access it from WAN to connect to the webportal to download the AnyConnect client, webpage, does work locally, this uses a secondary internet connection only for this connection, It's connected into the ISP Bridged output.
Connection arrives, then says routing failed, and I am stuck, I've had this problem before but don't know how I fixed,
This is the ACLimage.png  and yes this vpn is to have total LAN access
Thanks in advanced!
You're missing the default route, i don't see it in your config.
Can you verify with show route please?
If not there, can you add it and test again?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
6 Replies 6
Francesco Molino
Can you share your config please by removing any confidential information?
Also what is the IP 192.168.1.50?
There are some ways to achieve this by having anyconnect on the 2nd isp but just want to make sure first what you've done so far and what is the private IP we're seeing in the log.
Francesco
ISP Doesn't allow for public ip to ASA so I just used the bridge mode on it, that ip is just the IP of the Outside interface, that I would DMZ(on bad ISP router) to be able to use anyconnect
My config is (pastebin link): https://pastebin.com/rbaiQq8i
This asa is only for a Any Connect VPN, nothing else
First of all i don't recommend using the same subnet for the vpn pool and inside zone.
On your isp router, port 443 is forwarded to your asa?
While connecting, can you run debug webvpn anyconnect 255 and share the output please?
Francesco
About using the same subnet for pool and inside is beacause I use this as my mgmt vpn, via a secundary ISP, hence the fact I want to be able to reach everything on my LAN, the asa (192.168.1.50) is on a DMZ on the ISP router plugged into the bridged port.
About the debug for some reason nothing shows up, it says it is enabled but no output PS: I can access the portal from LAN but when the request comes from wan, it just says that route error on the main post
Hello, update, packets can go from WAN to the Outside IP and reach 443 of the ASA, but for some reason packets are droped then with this msg: routing failed to locate next hop for tcp from outside
Francesco
