Urgent! How to automatize command clear line tty 1
webstd.design
Please help to automatize command clear line tty 1
There is a dial-up link, which is frozen (not broken), every 15 min, is it possible to run command clear line tty 1 every 15 min?
Alex
5 Replies 5
webstd.design
or there is any command which may dnot rop the line on dial-up connection
do we need to configure something on line 1 for dial-up connection? no commands configured now
You can write EEM script which will clear tty line every 15 min for you.
Best Regards
Please rate helpful posts
Best Regards Please rate all helpful posts and close solved questions
For Your Info
Please See this it will help you.
https://supportforums.cisco.com/thread/2178860
Jawad
I've used this solution as workaround
http://www.cisco.com/en/US/docs/ios/12_3/feature/guide/g_kron.html
Probably somebody know why dial-up line freezes while sh line shows that line is up?
