*URGENT* SSH default port change, and access from WAN
shuklavikas
Hello All,
I suspect my ISP has blocked port 22, so what I did. I have configured below. However when tried to access from WAN , it is not working.. "ssh -p 2222 username@WAN IP"
Please help guys..
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh port 2222 rotary 1
line vty 0 4
 rotary 1
Have you allowed TCP/2222 on the outside ACL?
Yes,
380 permit tcp any any eq 2222 log
390 permit udp any any eq 2222 log
You don't need UDP for that. Are you sure that there is no deny above these lines? For a test move them to the beginning. Has SSH ever worked from outside?
moved that to seq 5, yes ssh works from outside.
I have a business partner sitting in US, he says that he is not able to ssh on port 22 (suspect an ISP issue) though it can be ssh'ed from other region. so i thought to change it to 2222 and test it. But now I am not able to ssh it from anywhere on port 2222
P.S- Do I need to put "login local" on line vty or TACACS authentication will work?
