Urgent !!! Voice Feature Cards; Cisco AS5350
worldcalltel
I have an AS5350, with c5350-is-mz.123-10c.bin IOS installed. The box has a 4 e1 port and 2 Fast ethernet port. I wanted to check how many dsp's are capable. But when I enter the command show vfc, it says that this command is unrecognized. Is this mean that my box doesn't have any vfc installed or is it having a conflict with the IOS or worst the vfc is not working. I am not familiar with the hardware of Gateways.Could you please help me on this.
IOS (tm) 5350 Software (C5350-IS-M), Version 12.3(10c), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 02-Mar-05 17:09 by kellmill
Image text-base: 0x60008AFC, data-base: 0x61700000
ROM: System Bootstrap, Version 12.2(1r)1, RELEASE SOFTWARE (fc1)
BOOTLDR: 5350 Software (C5350-BOOT-M), Version 12.2(2)XB2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
AS5350 uptime is 5 days, 5 hours, 2 minutes
System image file is "flash:c5350-is-mz.123-10c.bin"
cisco AS5350 (R7K) processor (revision T) with 262144K/131072K bytes of memory.
Processor board ID JAE09096SHG
R7000 CPU at 250MHz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache
Last reset from power-on
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x32,
Board Hardware Version 3.34, Item Number 800-5171-02,
Board Revision C0, Serial Number JAE09096SHG,
PLD/ISP Version 2.2, Manufacture Date 24-Feb-2005.
Processor 0x14, MAC Address 0x0131945D928
Backplane HW Revision 1.0, Flash Type 5V
2 FastEthernet/IEEE 802.3 interface(s)
6 Serial network interface(s)
120 terminal line(s)
4 Channelized E1/PRI port(s)
512K bytes of non-volatile configuration memory.
65536K bytes of processor board System flash (Read/Write)
16384K bytes of processor board Boot flash (Read/Write)
smalkeric
Level 6
Level 6
First give the command Show diag and see the complete data displayed.This command will show you all the cards which the device supports . Based on this out put you will have to plan the next steps
