Use of CEF in Cisco router
knaik99
switches use ASICS to store FIB & adjacency table in CAM & TCAM which are in ASICS.
hence multilayer switches can do routing & switching very fast.
But routers do not use ASICS so how do they create CEF table and where it is stored ?
Richard Burts
In routers the CEF table is in volatile memory.
Rick
some Router is hybrid router
Joseph W. Doherty
"But routers do not use ASICS so how do they create CEF table and where it is stored ?"
Where stored?  As answered by @Richard Burts, main RAM.
How CEF table created?  Likely by software.
Regarding routers not using ASICs, as described by @MHM Cisco World, often "higher end" routers (e.g. ASR 1K series) do use "extra" hardware for acceleration of some "core" routing features.
