How to swing traffic TWO router two wan link failover
UCrypto
I have confuse in network design.Please see below diagram and please help me how to fix to get fully redundancy.In diagram,If WAN link of R1 is down,branches can detect WAN link of R1 is down and so they swing their traffic to R2. But our VRRP didn't know R1 WAN is down or not.So R1 is still primary and return traffic is fail,correct ? And our FW cannot detect the WAN and FW still forward the all traffic to R1 and traffic is fail,correct ? how to solve this issue ? What kind of scenario should i use ? do i need to change design or configuration ?
2 Accepted Solutions
Deepak Kumar
You can go with VRRP with SLA configuration. Here I am sharing a link for your easy understanding the behaviour of VRRP and SLA.
https://www.atlassian.com/blog/archives/clustering_cisco_routers_with
Deepak Kumar
Vote to all helpful Answer.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
This is called Embedded event manager.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/eem/configuration/12-4t/eem-12-4t-book/eem-policy-cli.html
If you asking then the configuration is already mentioned in the shared (by you) link.
Deepak Kumar
Deepak Kumar,
Deepak Kumar
Deepak Kumar
Deepak Kumar,
if i want to Shutdown LAN interface if my WAN network is down by using IP SLA ,how can i do ?
The below two are correct ?
https://community.cisco.com/t5/routing/tracking-with-ip-sla-and-shut-an-interface/td-p/1881878
http://shamimjahan.blogspot.com/2015/02/auto-interface-shutdown-and-auto.html
Deepak Kumar
Deepak Kumar,
indr44959
Now that you have plenty of compact swings to choose from go through the buyers™ guide and decide for yourself what features you need most in your ideal compact best baby swing for small spaces.
