Use of Routing Protocols
mudasir05
Hello All,
We have a network of a L3 switch, an ASA firewall,a router,L2 switch connected to some servers.All these are connected through inter-vlan routing.
In this scenario if i run any routing protocol what will be the advantage of that?
How data traffic will the routed in this scenario?
2 Accepted Solutions
Amit Shah
Routing Protocols are used in the implementation of routing algorithms to facilitate the exchange of routing information between networks, allowing routers to build routing tables dynamically.
I guess you're having one campus network only so you don't require routing protocol.
Amit
Hi Mudasir,
The benefits of running a routing protocol in your situation are as follows:
  1. Eliminates the need to install static routes (ip route x.x.x.x) manually on your router/ASA.
  2. If you decide to expand, (add additional routers or ASAs) all you will have to do is connect them, enable your routing protocol on them and they will find the best path through your network.
Those are the two main reasons for your scenario. There are of course other more specific reasons depending on what you are trying to accomplish.
-Mario
Amit Shah
Amit
Thanks Amit,yes we are having one campus network....
just curious to know in case i run any routing protocol in the said scenario what benefits will it serve.
Hi Mudasir,
-Mario
