User Exec access while TACACS is down
todd.martin
I have a requirement to provide user-exec access to a router(s).
These routers are normally on TACACS, but when TACACS is unreachable, they need to login with local credentials that are different from that of the engineering team.
How can I set up user exec access that will authenticate locally without giving them the enable password?
paolo bevilacqua
you configure username, password and the desired privilege level. Then in aaa configuration just put local after tacacs.
Todd
paolo has given the answer that seems to meet your requirements. There is an aspect that you need to consider before you implement this. When you configure aaa authentication you can list several methods. The router attempts to use the first method and if there is an error it will try the next method. So if you configure aaa authentication listing tacacs as the first method and listing local as the second method then the router will attempt tacacs and if there is an error it will prompt for a user name and password which are configured on the router. Be aware that it will do this for all users. Your post indicated that these users would have access rights different from the engineering group. With the suggestion from paolo it will treat both groups the same and you will need configured name and password not only for these users but also for the engineering group. Is that ok?
Rick
Rick
