user without ssh, console port only
Andrzej121
Hi, in my configuration there are several users and a radius server, I log in to everything with SSH.
Now I need to create a user that can only be connected via the console port.
and as soon as I create a user with the command
username cisco privilege 15 password 0 cisco
So I log in to it via ssh my vty looks like this:
line vty 0 4
session-timeout 60
transport input ssh
How to block ssh in user cisco?
6 Replies 6
Torbjørn
What does your aaa config look like?
You can specify login for console and the VTYs separately like so:
! Default login for everything but console that excludes local useraccounts
aaa authentication login default group radius
!  Login for console specifically that only allows local useraccounts
aaa authentication login CONSOLE local
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Andrzej121
aaa authentication login default local group radius
aaa authentication login xxxx local
aaa authentication login cisco local
aaa authorization exec default local group radius
aaa authorization network default local group radius
aaa accounting exec default start-stop group radius
aaa accounting system default start-stop group radius
Your current settings for "default" authentication is to authenticate to local users first and fallback to radius if local auth fails.
Here are a couple suggestions to AAA config for default authentication(any authentication that is not otherwise specified):
! Authenticate with radius first, fallback to local user authentication in case RADIUS is unavailable .
aaa authentication login default group radius local
! Allow _only_ RADIUS auth.
Here are a couple suggestions to AAA config for console access:
! Allow fallback local user authentication for SSH in case RADIUS is unavailable .
aaa authentication login console group radius local
! Allow _only_ local auth for console access
aaa authentication login console local
Andrzej121
but at this moment user xxxx also does not have SSH access. Is it possible that the xxxx user will have access via SSH and the cisco user will only have access via the console port?
You can use
Line console 0
Login
Password xxxx
Note:- this way device ask for password only not ask both username and password
Note:- add enable password to device
Note:- make so so sure you can access via vty and console before WR
MHM
Andrzej121
If I have it this way
and I'll add it
Line console 0
login cisco
Password xxxx
then I can access user xxxx and cisco via ssh,
and when I have this:
I can't access user xxxx and cisco via ssh, And I would like to get to user xxxx via ssh, but not cisco.
I started to wonder if it is possible what I want to do, my device is cisco C921-4P
