users cannot access internet
edwincharles
dears ,
i am trying to setup LAN network as attached,pls find the current config
users are not able to acces internet, from switch cannot ping 8.8.8.8, from ASA can ping 8.8.8.8
2 Accepted Solutions
Thank you Edwin, perfect, from the firewall you can ping the ip 8.8.8.8?
Also please remove this line:
no access-list ouside_in extended permit icmp host 172.16.32.253 any
you should have
access-list ouside_in extended permit icmp any any echo
access-list ouside_in extended permit icmp any any echo-reply
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you
Could  you please execute the command ip routing on the switch? and try again.
19 Replies 19
Julio E. Moisa
Hi Edwin
Your config looks fine but the access-group configuration is missed. It is essential to enable the ACLs.
access-group <acl name> in interface <namif associated to the acl>
example
access-group <INSIDE-ACL> in interface <inside>
I used to create the NAT using object-groups along with the NAT statement.
Hope it is useful
Hi Julio,
can you help me on it
Sure,
Please me provide you an example, before I could confirm communication from the firewall to the gateways of the networks configured on the switch?
Try to executing these command lines:
Your NAT statement is ok so you dont need the following line:
no nat (inside,outside) after-auto source dynamic any interface
To enable the ACLs and apply it to the interface
access-group inside_access_in interface inside.
Please try and keep me posted. Also verify if the computers have the gateway configured and DNS addresses like 8.8.8.8 / 4.2.2.2
I can ping from switch 8.8.8.8
from user cannot ping 8.8.8.8 and no internet
attached new config of asa
They already should have Internet access, in order to enable ping try these commands:
access-list inside_access_in line 1 extended permit icmp 10.10.0.0 255.255.0.0 any echo
access-list inside_access_in line 2 extended permit icmp 10.10.0.0 255.255.0.0 any echo-reply
access-list ouside_in line 1 extended permit icmp host 172.16.32.253 any echo
access-list ouside_in line 2 extended permit icmp host 172.16.32.253 any echo-reply
Usually icmp is not part of IP, you need to enable icmp on both ways.
dear julio,
no successs, no internet
cannot ping 8.8.8.8
not able to ping the modem also
Thanks for the update,
Just a question about the IP configured under the outside interface, is it the IP of the network received through the modem? or it is the gateway? and the default route should be pointing to gateway, do you know what is the gateway for the subnet 172.16.32.0/24?
If you connect a PC to the modem, can you see what IP you obtained from the modem?
interface GigabitEthernet1/1
 description to WAN
 nameif outside
 security-level 0
 ip address 172.16.32.1 255.255.255.0
route outside 0.0.0.0 0.0.0.0 172.16.32.253
172.16.32.253 is IP of the DSL MODEM
Thank you,
If you connect a PC to the modem, can you see what IP you obtained and its gateway from the modem?
attached ip getting when directly connected to pc
you should have
yes, I can
Your firewall config looks fine, can you set up a PC manually and use DNS 8.8.8.8 and 4.2.2.2
Also Im assuming the ip routing command is configured on the layer 3 switch, is that correct?
