08-19-2005 02:28 PM - edited 03-03-2019 10:18 AM
Hi!
Is this limit a hard? Can router support, for example 25 clients or it will work with maximum 20?
Thank you.
Solved! Go to Solution.
08-19-2005 06:54 PM
20 is the recommended number and probably Cisco would have performed a performance testing on that platform and recommend the optimum number as 20. I dont think you will have any issues if you use 25, but if you run into trouble and call TAC for support, they will probably recommend you to upgrade your router to a higher model to support that many users.
08-19-2005 06:54 PM
