Uses for RIPng?
Wzshelefka
The book describes RIPng as “one of the easiest routing protocols to configure, making it a good choice for small networks”, but I disagree. If I were implementing routing for IPv6 I would choose OSPFv3 or EIGRP for IPv6. I cannot seem to find any real world examples of using RIPng. Does anyone know of or implement RIPng in real world situations?
Thank you
5 Replies 5
mvsheik123
Level 7
Level 7
Agree that it all depends on your interest and future network growth. However, as it mentioned 'good choice for small network' - I agree with this as there is no complexity in configuration. The hop count makes it straight forward setup (compared to OSPF or EIGRP) for small networks. I don't think there is authentication related configs or anything. This is relatively small information with ref to RIPng. however, I suggest you check RFC 2080 for RIPng.
hth
MS
Julio E. Moisa
I agree, unfortunately I have not heard about RIPng implementations. I prefer EIGRP for IPv6 or OSPFv3. Im not sure but RIP could be used for some technicians by simplicity in the configuration into smallest networks.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Philip D'Ath
You'll probably find RIPng comes "standard" in a lot of images, while OSPFv3 and EIGRP require additional licences on many devices.
So if it was a small network, would you want to pay [probably a lot] extra and end up with the same result?
Seb Rupik
I'll admit it, the university I worked at ran RIPng between the core and the linux IPv6 firewalls for the whole campus.
I don't know what the motivations were for the deployment but it was something that I maintained and ran in production for....years :)
cheers,
Seb.
Seb
Thank you for providing a real world example of an implementation of RIPng. I suspect that a large part of the motivation was that there needed to be a routing function of Linux devices. That pretty much eliminates the possibility of using EIGRP and it may very well be that OSPF was a stretch. I have been involved in some customer networks where there were devices in the network where the vendor did not provide support for EIGRP or for OSPF but did provide support for RIP. So there are instances where device compatibility comes into play when choosing a routing protocol.
There have been a couple of responses which have expressed the opinion that the poster would certainly prefer to use EIGRP or OSPF. I am confident that these opinions came from people who have developed skills in working in complex environments and that need sophisticated network engineers. And for those organizations it is generally true that more sophisticated routing protocols are preferred. But there are organizations out there whose networks are not so large and not so complicated and for whom a simple, easy to implement, does not take much analysis routing protocol is appropriate. I have worked for a couple of them. Think about light weight protocols, perhaps TFTP and FTP are examples. If we are transferring lots of data where efficiency of transfer, and lots of operational parameters can be used to optimize operation, then clearly FTP is the better protocol. So why do so many of us use TFTP so much when FTP is the more capable protocol? It is because it is more light weight, simpler to operate, and it gets the job done. Perhaps we can think about routing protocols in the same way.
Rick
Rick
