using a 3750 switch to route
lcaruso
Level 6
Level 6
I need to use a 3750 switch running 12.2 code to route between two networks in a test setup.
Switch#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
The idea for the test setup is 3750 emulates a client's live network which is two routers having a site-to-site tunnel connecting from their ISPs. This will allow me to test the tunnel configuration with the router configs that are in production but replacing one of the routers with an ASA.
My question is how do I use the 3750 to do this?
I assume create two vlans with ip addressing that replicates each router’s isp connection, assign those to different switchports, and connect the router and the ASA to  those switchports, but what about the routing?
Or is the above approach wrong to begin with? Thanks for any guidance.
hobbe
Level 7
Level 7
You are on the right track, I use my 3750x like that all the time.
its perfect to test IPsec tunnels and firewall stuff aswell.
There is actually two ways of doing this.
all virtual with svi
interface gig1/0/1
switchport access vlan 10
switchport mode access
interface gig1/0/2
switchport access vlan 20
interface Vlan10
ip address 192.168.10.1 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
To start routing you need to specify the command:
ip routing
Or if you want to do it with cables.
Interface gig1/0/1
no switchport
interface gig1/0/2
no switchport
Interface gig1/0/3
Switchport access vlan 10
interface gig 1/0/4
Interface gig 1/0/5
interface gig 1/0/6
If you do it with cables then you have the possibillity to pull the cables to test connectivity fx.
and ofcourse you need to do a no shut on any interface that is shutdown.
Good luck
Message was edited by: hobbe
lcaruso
Level 6
Level 6
Something like this?
IP routing
Vlan 851
Name 851_router
Vlan 1811
Name 1811_router
Interface vlan851
Ip address x.x.x.x 255.255.255.0
No shut
Interface vlan1811
No shut
Interface Fa 1/0/1
Switchport mode access
Switcport access vlan 851
No shut
Interface Fa 1/0/2
Switcport access vlan1811
No shut
hobbe
Level 7
Level 7
interface gig1/0/1
interface gig1/0/2
interface Vlan10
interface Vlan20
ip routing
Interface gig1/0/1
no switchport
interface gig1/0/2
no switchport
Interface gig1/0/3
interface gig 1/0/4
Interface gig 1/0/5
interface gig 1/0/6
Good luck
Thanks for your response.
