Using BGP with VRF's to Emulate MPLS and Internet
kenny.kerns
I am setting up a lab network to emulate our production network and am using a single 2851 to emulate both my MPLS provider (only running BGP, not actually running MPLS) and our ISP that we use for our DMVPN secondary network.
Because I am using one router to function as both service providers I am running VRF's to keep the routing tables seperated. So far basic connectivity works fine, I can ping from the PE 'MPLS' VRF to the datacenter CE interface and the ISP side is working as well.
Pinging across the ISP VRF
lab-isp#ping vrf TW 66.193.134.46
Sending 5, 100-byte ICMP Echos to 66.193.134.46, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Pinging across the 'MPLS' VRF
lab-isp#ping vrf CL 63.156.111.46
Sending 5, 100-byte ICMP Echos to 63.156.111.46, timeout is 2 seconds:
BGP is up from both the datacenter MPLS CE and the datacenter internet router.
BGP on the datacenter internet router
lab-dc1-inet#sh ip bgp summ
BGP router identifier 66.193.134.46, local AS number 33415
BGP table version is 4, main routing table version 4
1 network entries using 117 bytes of memory
1 path entries using 52 bytes of memory
2/1 BGP path/bestpath attribute entries using 248 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 417 total bytes of memory
BGP activity 2/1 prefixes, 2/1 paths, scan interval 60 secs
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
66.193.134.45   4  1000      37      37        4    0    0 00:23:23        0
BGP on the datacenter MPLS CE
lab-dc1-1#sh ip bgp summ
BGP router identifier 10.152.1.250, local AS number 65000
BGP table version is 2, main routing table version 2
1 network entries using 136 bytes of memory
1 path entries using 56 bytes of memory
1/0 BGP path/bestpath attribute entries using 128 bytes of memory
BGP using 320 total bytes of memory
BGP activity 1/0 prefixes, 1/0 paths, scan interval 60 secs
63.156.111.45   4          209     156     158        2    0    0 00:24:19        0
But, BGP is idle on the MPLS PE/ISP router.
BGP on the datacenter MPLS PE/ISP router
lab-isp#sh ip bgp summ
BGP router identifier 63.156.111.45, local AS number 209
BGP table version is 1, main routing table version 1
63.156.111.46   4        65000       0       0        1    0    0 never    Idle
66.193.134.46   4        33415       0       0        1    0    0 never    Idle
lab-isp#
This is my first attempt at using VRF's in this fashion and could have easily missed something or used a config that is not nessesary.
Here is the configuration on the MPLS PE/Internet router.
ip vrf CL
rd 1:1
route-target export 1:1
route-target import 1:1
ip vrf TW
rd 2:2
route-target export 2:2
route-target import 2:2
interface GigabitEthernet0/0.1
description lab-dc1-1
encapsulation dot1Q 10
ip vrf forwarding CL
ip address 63.156.111.45 255.255.255.252
interface GigabitEthernet0/0.2
description lab-sea-1
encapsulation dot1Q 11
ip address 63.156.111.17 255.255.255.252
interface GigabitEthernet0/1.1
description lab-dc1-inet
encapsulation dot1Q 20
ip vrf forwarding TW
ip address 66.193.134.45 255.255.255.252
router bgp 209
bgp router-id 63.156.111.45
bgp log-neighbor-changes
neighbor 63.156.111.46 remote-as 65000
neighbor 66.193.134.46 remote-as 33415
address-family ipv4
  neighbor 63.156.111.46 activate
  neighbor 66.193.134.46 activate
exit-address-family
address-family ipv4 vrf CL
exit-address-family
address-family ipv4 vrf TW
  bgp router-id 66.193.134.45
  neighbor 66.193.134.46 local-as 1000
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip bgp-community new-format
kenny.kerns
I forgot to add the debug ip bgp output from the MPLS/Internet router. I have tried to add update-source to both the BGP and ipv4 family configs with no luck. I also added the multi-hop commands that are usually nessesary with update-source and still had the open active failed messages.
lab-isp#debug ip bgp
BGP debugging is on for address family: IPv4 Unicast
lab-isp#
*Nov  7 16:25:06.634: BGP: 66.193.134.46 Active open failed - update-source NULL is not available, open active delayed 8192ms (35000ms max, 60% jitter)
*Nov  7 16:25:14.826: BGP: 66.193.134.46 Active open failed - update-source NULL is not available, open active delayed 8192ms (35000ms max, 60% jitter)
*Nov  7 16:25:15.850: BGP: 63.156.111.46 Active open failed - update-source NULL is not available, open active delayed 7168ms (35000ms max, 60% jitter)
*Nov  7 16:25:23.018: BGP: 66.193.134.46 Active open failed - update-source NULL is not available, open active delayed 10240ms (35000ms max, 60% jitter)
*Nov  7 16:25:23.018: BGP: 63.156.111.46 Active open failed - update-source NULL is not available, open active delayed 7168ms (35000ms max, 60% jitter)
*Nov  7 16:25:30.186: BGP: 63.156.111.46 Active open failed - update-source NULL is not available, open active delayed 8192ms (35000ms max, 60% jitter)
*Nov  7 16:25:33.258: BGP: 66.193.134.46 Active open failed - update-source NULL is not available, open active delayed 9216ms (35000ms max, 60% jitter)un all
*Nov  7 16:25:38.378: BGP: 63.156.111.46 Active open failed - update-source NULL is not available, open active delayed 10240ms (35000ms max, 60% jitter)
