cisco 1841 easy configuration help
danieladaniela
Hi, can someone please help with the following configuration?
I have an ADSL modem, IP 192.168.1.1 which is connected to FastEthernet0/0 IP address 192.168.1.2 and then I would like to use the other ethernet interfaces to attach to it two wireless routers and possibly a machine or a third router.
For example I have interface 192.168.120.1 attached to a consumer router which has IP address 192.168.120.2 and it is connected LAN to LAN. I know, brutal setup, but I can't even get this to work. Everything is on subnet 255.255.255.0
The Cisco can ping the internet, it can ping the routers that are attached to it, it can also ping the machines I attach to the slave routers, say, 192.168.120.161 no problem. Here is the routing table
Router_1841#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
C    192.168.120.0/24 is directly connected, FastEthernet0/1/1
C    192.168.1.0/24 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 [1/0] via 192.168.1.1
Router_1841#
The machines can ping the ethernet interface of the cisco, the one connected to their slave router, but can't ping beyond that, ie, they can't ping external cisco interface 192.168.1.2 nor the modem 192.168.1.1 and obviously not the internet. The slave router can't ping either, not the internet and not the interface to outside 192.168.1.2 nor the modem. I suppose I have problems in the routing table which does not forward properly the internal network to the outside, I tried to do that, but it says incompatible netmasks or something and I can't figure out how to do properly. Perhaps I also have access-list problems. Setting this up is above my head and I am at my wit's end. Thank you a lot.
Router_1841#show run
Building configuration...
Current configuration : 1890 bytes
version 12.4
hostname Router_1841
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret xxxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxxxxxxxxxx
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool poolcisco
   network 10.1.10.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.1.2
ip cef
ip name-server 91.80.37.100
ip name-server 8.8.8.8
no ipv6 cef
archive
log config
  hidekeys
interface FastEthernet0/0
description outside
ip address 192.168.1.2 255.255.255.0
ip nat outside
ip virtual-reassembly
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
description dlinkLAN
ip address 192.168.125.1 255.255.255.0
ip nat inside
speed auto
full-duplex
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1/0
description linksysLAN
ip address 192.168.130.1 255.255.255.0
ip nat inside
speed auto
full-duplex
interface FastEthernet0/1/1
description dlink2LAN
ip address 192.168.120.1 255.255.255.0
ip nat inside
speed auto
full-duplex
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
no ip http secure-server
access-list 10 permit 192.168.96.0 0.0.30.255
access-list 101 permit ip 10.1.10.0 0.0.0.255 any
access-list 102 permit ip any 10.1.10.0 0.0.0.255
access-list 103 permit tcp any any
access-list 103 permit udp any any
access-list 103 permit icmp any any
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
remove the  nat inside and nat outside from the interfaces as i told you to
in the 1841 config you posted I see you have an interface in 192.168.120.0/24 subnet which is connected to other router so where is this 192.168.120.161 host located ? how is this slave router connected to the 1841 ? what is this slave router model ?
Regards.
Alain
11 Replies 11
cadet alain
try to remove the ip nat statements from the interfaces and on your adsl modem just configure static routes to the
120,125 and 130 network as well as to LAN devices subnet.
on the other routers put a static default route pointing to next-hop ip
if you still got problem pinging 192.168.1.2 then on 1841 do this:
logging buffered debug
logging buffered 100000
service timestamp debug uptime
access-list 190 permit icmp any any
do debug ip pack det 190
do debug ip icmp
then ping with a count of 2 from machine to 192.168.1.2 and issue do sh log then hit enter and paste output.
Regards.
Alain
Hi and thank you,
I am not sure the ADSL modem will allow me to set a route, because it is consumer equipment and a cheap one. Not that the operator is any better, see below, I suspect there is some gross misconfiguration. I have not implemented anything yet, this is logging of current state.
Why do I need to set a static route on the modem? It only has one connection in and another out. Should it not be able to do subnet masks and know which way to send things?
How do I remove nat? Like this for every interface?
no ip nat outside source route-map NAT interface FastEthernet0/0
no ip nat inside source route-map NAT interface FastEthernet0/1
Thanks again
Router_1841#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/59/60 ms
Router_1841#
1d00h: IP: s=192.168.1.2 (local), d=8.8.8.8, len 100, local feature
1d00h:     ICMP type=8, code=0, NAT(2), rtype 0, forus FALSE, sendself FALSE, mt
u 0, fwdchk FALSE
1d00h: FIBipv4-packet-proc: route packet from (local) src 192.168.1.2 dst 8.8.8.
8
1d00h: FIBipv4-packet-proc: packet routing succeeded
1d00h: IP: s=192.168.1.2 (local), d=8.8.8.8 (FastEthernet0/0), len 100, sending
1d00h: IP: s=192.168.1.2 (local), d=8.8.8.8 (FastEthernet0/0), len 100, output f
eature
1d00h:     ICMP type=8, code=0, Post-routing NAT Outside(17), rtype 1, forus FAL
SE, sendself FALSE, mtu 0, fwdchk FALSE
eature
1d00h:     ICMP type=8, code=0, Stateful Inspection(20), rtype 1, forus FALSE, s
full packet
1d00h: IP: s=8.8.8.8 (FastEthernet0/0), d=192.168.1.2, len 92, input feature
1d00h:     ICMP type=0, code=0, Stateful Inspection(4), rtype 0, forus FALSE, se
1d00h:     ICMP type=0, code=0, Virtual Fragment Reassembly(21), rtype 0, forus
FALSE, sendself FALSE, mtu 0, fwdchk FALSE
1d00h:     ICMP type=0, code=0, Virtual Fragment Reassembly After IPSec Decrypti
on(32), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
1d00h:     ICMP type=0, code=0, NAT Outside(53), rtype 0, forus FALSE, sendself
1d00h:     ICMP type=0, code=0, MCI Check(64), rtype 0, forus FALSE, sendself FA
1d00h: FIBipv4-packet-proc: route packet from FastEthernet0/0 src 8.8.8.8 dst 19
2.168.1.2
1d00h: FIBfwd-proc: Default:192.168.1.2/32 receive entry
1d00h: FIBipv4-packet-proc: packet routing failed
1d00h: IP: tableid=0, s=8.8.8.8 (FastEthernet0/0), d=192.168.1.2 (FastEthernet0/
0), routed via RIB
1d00h: IP: s=8.8.8.8 (FastEthernet0/0), d=192.168.1.2 (FastEthernet0/0), len 92,
output feature
1d00h:     ICMP type=0, code=0, Post-routing NAT Outside(17), rtype 1, forus FAL
output feature
1d00h:     ICMP type=0, code=0, Stateful Inspection(20), rtype 1, forus FALSE, s
rcvd 3
1d00h: IP: s=8.8.8.8 (FastEthernet0/0), d=192.168.1.2, len 92, stop process pak
for forus packet
1d00h: ICMP: echo reply rcvd, src 8.8.8.8, dst 192.168.1.2
u 0, fwdchk FALSE
8
eature
eature
full packet
2.168.1.2
0), routed via RIB
output feature
output feature
rcvd 3
for forus packet
u 0, fwdchk FALSE
8
eature
eature
full packet
2.168.1.2
0), routed via RIB
output feature
output feature
rcvd 3
for forus packet
u 0, fwdchk FALSE
8
eature
eature
full packet
2.168.1.2
0), routed via RIB
output feature
output feature
rcvd 3
for forus packet
u 0, fwdchk FALSE
8
eature
eature
full packet
2.168.1.2
0), routed via RIB
output feature
output feature
rcvd 3
for forus packet
Router_1841#
first you had no nat stement except the nat inside and nat outside on your interfaces on the original post where you posted the config.
second what you did is ping from 1841 to 8.8.8.8 but that is not what i was asking for: take a machine connected to a far router and ping 192.168.1.2 and do clear log before then post log again as well as sh ip nat trans output but could you also post your nat config too please:
sh run | s nat|access-list|route-map
But you'll need a default route on each router and  static routes on the 1841 for the subnets behind the router connected to 1841 as well  as on intermediary routers behind the 1841 or else you could use a routing protocol like rip.
Regards.
Alain
Hi and thank you.
I don't understand the NAT and I am not sure what it does exactly, because I am not really connecting subnets e.g. from different service providers. Right now, I am trying the most simple configurations. But, before I put it, it did not ping anything. As you can see below, it is empty.
I tried to do what you said and nothing happened at all, if I try to ping 192.168.1.2 from the machine which is 192.168.120.161 and also I get nothing if I ping from slaverouter 192.168.120.2
Router_1841#sh ip nat trans
Router_1841#sh run | s nat|access-list|route-map
ip nat outside
ip nat inside
ip nat inside
ip nat inside
Router_1841#
Regards.
Alain
Thank you a lot, it looks like I finally successfully removed the NAT. Apologies, I have to look up the commands
I tried again pinging from the machine and nothing happened. Log is still enabled. Cisco can ping the slave router, but it can not ping the machine any more.
Current configuration : 1828 bytes
version 12.4
service timestamps debug uptime
boot-start-marker
boot-end-marker
enable secret 5 $1$vCYN$eOwyxxxxxxxxxxxxx
no aaa new-model
dot11 syslog
ip source-route
   dns-server 8.8.8.8
ip cef
no ipv6 cef
archive
log config
  hidekeys
description outside
speed auto
full-duplex
no mop enabled
speed auto
full-duplex
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
speed auto
full-duplex
ip nat inside
speed auto
full-duplex
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router_1841#
ip nat inside
speed auto
full-duplex
Remove this also and  post a diagram please.
Regards.
Alain
Yes, I have a physical cable that goes from the FE0/1/1 to a LAN port of this router. Previously, I tried to use WAN-LAN connection and call the interface 192.168.120.1 and the router 192.168.121.1 et cetera, but this did not work either.
This is a little embedded PC and I have it connected to the slave router via ethernet.
via ethernet cable, LAN to LAN as I mentioned before. The embedded also has a browser window from which I access the slaverouter and do things such as pinging.
Since I know that consumer equipment can be wierd, after a few days of problems I have made sure to have various options available. At the moment the 120.2 is a D-link DIR-825, the 130.2 is a Lynksys (i figured it's more Cisco-friendly) wrt-54gl, and the 125.2 is an old di-524.
I can try and connect a machine directly to the Cisco1841 ethernet if it is helpful.
Thanks again, and I am rating 5* all your posts. This is extremely helpful.
Yes hold on, I will post the diagram. But I can't seem to get rid of the NAT
Router_1841#configure
Configuring from terminal, memory, or network [terminal]?
Enter configuration commands, one per line.  End with CNTL/Z.
Router_1841(config)#interface fastethernet0/1/1
Router_1841(config-if)#no ip nat inside
Router_1841(config-if)#end
Router_1841#
*Nov  7 16:35:54.849: %SYS-5-CONFIG_I: Configured from console by console
Router_1841#
Router_1841#
and there is more
Router_1841#show ip interface brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
FastEthernet0/0            192.168.1.2     YES manual up                    up
FastEthernet0/1            192.168.125.1   YES manual up                    up
Serial0/0/0                unassigned      YES NVRAM  administratively down down
Serial0/0/1                unassigned      YES NVRAM  administratively down down
FastEthernet0/1/0          192.168.130.1   YES manual up                    up
FastEthernet0/1/1          192.168.120.1   YES manual up                    up
NVI0                       192.168.1.2     YES unset  up                    up
Router_1841#
On the other hand it seems gone from show run
speed auto
full-duplex
sorry, i am with mobile connection, I hope my sketch is readable, thanks again
send me a Private message
Regards.
Alain
