Using Cisco Shell
bavo
Hi all,
I have a question,
We are using shell scripts to configure items on the switch.
We are replacing the older "C3560" switches from our network. We a replacing them with the newer "C3650" series.
But we are unable to get the shell scripts working with the new switch.
the config command for the 3560 switch was "shell init file tftp://172.x.x.x/shell/interface"
The newer 3650 switch does accept the commando but the shell does not work. If been looking for some time now but no solution.
It is possible that the shell is not supported on the new C3650 series of switches. But I cannot find that in the documentation.
I hope someone can help me with this
C3560 is running 122-55.SE8.bin
C3650 is running 03.03.05SE
Thanks in advanced
Greetings
Palermo
Ruben Cocheno
check using this
router(config)#shell processing full
router(config)#shell init {filename:URL no-exec}
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
