using IPSLA and Track for multiple static routes
cyr0nk0r1
Here is our setup.
Datacenter1 = DC1
Datacenter2 = DC2
Point to Point1 = PTP1
Point to Point2 = PTP2
Internet = INET
We have some Cisco 3650's that we want to configure a static route for a new point to point being setup between our 2 datacenters. We will be turning the switchports on each core that connects to the point to point into L3 routed ports. We also have an internet connection.
My issue is how to handle 3 separate routes in cores that are not stacked.
On Core1 I would setup the following.
ip sla 1
icmp-echo 10.9.0.1 source-interface gig0/20
threshold 10
timeout 1000
frequency 2
ip sla schedule 1 life forever start-time now
ip route 10.9.0.0 255.255.0.0 x.x.x.x track 1 (x.x.x.x = L3 IP of PTP1)
ip route 10.9.0.0 255.255.0.0 10.219.254.10 10
This is easy enough, but I'm unclear on how to scale this out when I have PTP2 on Core2. How do I make PTP1 the primary static route for 10.9.0.0 on core 1, but then if the 10.9.0.1 IP becomes unavailable, rather than sending to my 10.219.254.10 route I send it to Core2 PTP2..... THEN if Core PTP2 is ALSO unavailable THEN send it out the 10.219.254.10?
That's my trouble. Am I explaining it correctly?
9 Replies 9
user1024
You will need another route that points to the other next hop (PTP2) with an AD higher than the primary route but lower than the last resort. You will also need another IP SLA and track configuration to verify reach-ability for the secondary route.
This type of configuration tends not to scale very well, is it possible to utilize dynamic routing in your environment?
you indeed need three static routes, two SLAs, and a boolean track list. Below is a configuration example. If you cannot work out how to translate it to your own configuration, post the full running configuration so we can customize it.
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
track 3 list boolean or
object 1
object 2
interface FastEthernet0/0
description ISP Primary
ip address 100.100.100.1 255.255.255.252
duplex auto
speed auto
media-type rj45
interface FastEthernet0/1
description ISP Secondary
ip address 150.150.150.1 255.255.255.252
duplex auto
speed auto
media-type rj45
interface FastEthernet0/2
ip address 200.200.200.1 255.255.255.252
description ISP Terciary
duplex auto
speed auto
media-type rj45
ip route 0.0.0.0 0.0.0.0 100.100.100.2 track 1
ip route 0.0.0.0 0.0.0.0 150.150.150.2 100 track 2
ip route 0.0.0.0 0.0.0.0 200.200.2000.2 200
ip sla 1
icmp-echo 8.8.8.8 source-interface FastEthernet0/0
threshold 1000
timeout 3000
frequency 3
ip sla 2
icmp-echo 8.8.8.8 source-interface FastEthernet0/1
threshold 1000
timeout 3000
frequency 3
ip sla schedule 2 life forever start-time now
event manager applet CLEAR_NAT
event track 3 state any
action 1.0 cli command “enable”
action 2.0 cli command “clear ip nat translation *”
action 3.0 cli command "end"
This is very helpful. The one thing that I don't think is addressed is the following.
MPLS1, MPLS2, and Internet are not all plugged into the same core.
I have 2 cores, which are not stacked.
So MPLS1 is plugged into core 1, MPLS2 is plugged into core 2, and Internet is plugged into both cores using an HSRP next hop IP.
The thing I'm having trouble wrapping my head around is how to configure for the following scenario.
For inter datacenter traffic we want to use MPLS1 as the primary link. If MPLS1 goes down or the next hop is unreachable, we want to send inter datacenter traffic out MPLS2. If MPLS2 also goes down or next hop is unreachable, then use Internet HSRP next hop IP.
My head is having trouble with "if core1 mpls1 goes down, core 1 needs to send traffic to core 2's mpls2. But core2 will need to know core1 mpls1 is down also so as to not try and redirect the traffic back to core1 mpls1.
Also, can you explain the event manager applet commands. What are these doing? Why are these needed?
Core1 L3 IP - 100.100.100.1 <> 100.100.100.2
Core2 L3 IP - 150.150.150.1 <> 150.150.150.2
Internet - 10.219.254.10
CORE1
int gig1/0/1
description CORE1-MPLS1
int gig1/0/3
description INTERNET
switchport mode access
switchport access vlan 999
ip route 10.119.0.0 255.255.0.0 100.100.100.2 track 1
ip route 10.119.0.0 255.255.0.0 150.150.150.2 100 track 2
ip route 10.119.0.0 255.255.0.0 10.219.254.10 200
ip route 0.0.0.0 0.0.0.0 10.219.254.10
ip sla 1
icmp-echo 100.100.100.2 source-interface gig1/0/1
threshold 10
timeout 1000
frequency 2
ip sla 2
icmp-echo 150.150.150.2 source-interface gig/1/0/1
threshold 10
timeout 1000
frequency 2
CORE2
int gig1/0/1
description CORE2-MPLS2
int gig1/0/3
ip sla 1
threshold 10
timeout 1000
frequency 2
ip sla 2
threshold 10
timeout 1000
frequency 2
can you post a schematic drawing of your topology, so we can see exactly what is connected to what ? With 'not stacked' you mean not connected to each other ?
The EEM script clears the NAT translations in case of a failover so you don't have to wait for them to timeout...
Are you running HSRP to provide gateway redundancy for devices behind the core that need to get routed over the MPLS? As Georg mentioned a diagram would be helpful.
Relevant topology
The 2 switches are L3 switches, not stacked, just plugged into each other via a port channel. The upstream device is a firewall that handles the internet static route. These switches are Core 1, and Core 2. The other datacenter is an exact mirror of this topology.
On Core1:
interface GigabitEthernet0/20
description MPLS
no switchport
ip address 10.255.255.1 255.255.255.252
interface Vlan150
description MPLS-TEST-VLAN
ip address 10.101.150.2 255.255.255.0
standby version 2
standby 150 ip 10.101.150.1
standby 150 priority 200
standby 150 preempt
ip sla 150
icmp-echo 10.255.255.2 source-interface gig0/20
threshold 10
timeout 1000
frequency 2
ip sla schedule 150 life forever start-time now
track 150 ip sla 150 reachability
ip route 10.101.0.0 255.255.0.0 10.255.255.2 track 150
ip route 10.101.0.0 255.255.0.0 10.219.254.10 100
! default route
the config looks good. I guess you need the same, mirrored configuration on the Core 2 switch.
So I've not had trouble wrapping my head around this config for a single core MPLS.
The problem I'm having trouble with is how would I configure this such that if Core1 goes down, it sends it over to Core2's MPLS. But Core2's IPSLA needs to be aware that Core1's MPLS is down also so it doesn't try and route back to Core1 in a routing loop.
One of my big questions is, if I'm using an IP SLA to track a link on another switch, what would be my source interface to monitor the MPLS on core 2 on core 1? Would the source interface be the port channel on core1 over to core2?
The above example given by Georg assumes that both MPLS links are on the same switch.
You also need to decrement the HSRP priority of the primary device when the track fails. This will allow the secondary to takeover.
