Using NBAR to filter Peer-to-Peer P2P Traffic
ken
I am using a 3925 router running 15.1(1)T software.  The router has four interfaces:
GBE0/0     WAN/Internet
GBE0/1     LAN1
GBE0/2     LAN2
GBE0/3     LAN3
LAN1, LAN2 and LAN3 are seperate networks addressed with public addresses in a single /22 block.  LAN1 is a /23 and LAN2 & LAN3 are /24.
I am attempting to block users on the internal networks from using Peer-to-Peer software to download copyrighted content.  To do so, I followed the instructions in the CLI portion (top half) of http://www.cisco.com/en/US/products/ps5855/products_configuration_example09186a0080ac3082.shtml
The configuration example above details loading PDLM files for each of the protocols NBAR should classify.  But I couldn't locate any PDLM files for the 3925 and it seems to be working without them.  #show ip nbar pdlm returns nothing, but #show policy-map interface GigabitEther0/1 returns:
  Service-policy input: P2P-QoS-Policy
    Class-map: p2p (match-any)
      316994 packets, 39602624 bytes
      5 minute offered rate 41000 bps, drop rate 41000 bps
      Match: protocol fasttrack
        3 packets, 180 bytes
        5 minute rate 0 bps
      Match: protocol gnutella
        71 packets, 9817 bytes
        5 minute rate 0 bps
      Match: protocol kazaa2
        7 packets, 1106 bytes
        5 minute rate 0 bps
      Match: protocol edonkey
        53 packets, 6220 bytes
        5 minute rate 0 bps
      Match: protocol winmx
        32 packets, 3451 bytes
        5 minute rate 0 bps
      Match: protocol bittorrent
        123988 packets, 14638612 bytes
        5 minute rate 41000 bps
      Match: protocol directconnect
        922 packets, 297410 bytes
        5 minute rate 0 bps
      Match: access-group 109
        4 packets, 333 bytes
        5 minute rate 0 bps
      drop
Am I interpretting this correctly?  Does this show that it's classifying the traffic despite no PDLM files being loaded?
Here's the pertinent parts of my actual configuration.  I would appreciate any critique or suggestions for improving it:
ip cef
policy-map P2P-QoS-Policy
class p2p
   drop
interface GigabitEthernet0/0
description WAN_Internet
ip address ###.###.###.### 255.255.255.252
duplex full
speed 100
no cdp enable
interface GigabitEthernet0/1
description LAN1
ip address XXX.XXX.XXX.XXX 255.255.254.0
ip nbar protocol-discovery
duplex auto
speed auto
no snmp trap link-status
no cdp enable
no mop enabled
service-policy input P2P-QoS-Policy
interface GigabitEthernet0/2
description LAN2
ip address YYY.YYY.YYY.YYY 255.255.255.0
duplex auto
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/0/0
description LAN3
ip address ZZZ.ZZZ.ZZZ.ZZZ 255.255.255.0
duplex auto
speed auto
class-map match-any p2p
match protocol fasttrack
match protocol gnutella
match protocol kazaa2
match protocol edonkey
match protocol winmx
match protocol bittorrent
match protocol directconnect
match access-group 109
class p2p
   drop
access-list 109 remark P2P-Qos Category=256
access-list 109 remark Outgoing Traffic
access-list 109 permit ip XYZ.XYZ.XYZ.XYZ 0.0.3.255 ###.###.###.### 0.0.0.3
access-list 109 remark Incoming Traffic
access-list 109 permit ip ###.###.###.### 0.0.0.3 XYZ.XYZ.XYZ.XYZ 0.0.3.255
Thanks for having a look.  I appreciate any suggestions!
Nandan Mathure
Hi !
I tested this and this is what I found.
I believe that pdlms which are bundled in the ios dont show up with command "show ip nbar pdlm". Once you download and install the pdlm with the command "ip nbar pdlm" then you will get output for the specific pdlm only.
Nandan Mathure
