Using NTP as a VPN Keepalive
Dean Romanelli
Level 4
Level 4
Hi All,
I have an IPSec site-to-site VPN tunnel between two ASA 5505's, and the tunnel keeps dropping due to inactivity. Through research, trial & error, I have found that using NTP to keep the tunnel alive is probably going to be the best workaround.  I will point the ntp polling to a destination address within the interesting traffic (the LAN of the far-end of the VPN tunnel).  However, there are no formal NTP servers on that far-end LAN, which is where my question comes in:
Does the NTP poll mechanism on the ASA first send an ICMP ping to whatever you specify as the NTP server before it actually pulls the time?  I don't care as much if it doesn't get the time as much as I do that successful traffic to keep the tunnel up will be sent.
Mark Malone
just another option if your software version supports it , use an ip sla probe to keep it up
or try and set the idle timeout vpn-idle-timeout xxxx
https://supportforums.cisco.com/discussion/10987781/unlimited-idle-timeout-idle-timeout-session-30-minutes
Hi Mark,
Thanks for replying. Unfortunately ip sla doesn't work because there is no way to source the ping from the inside interface of the ASA, which means the ping attempt will not go over the tunnel.  To do that I would have to permit the WAN IP of the ASA in the interesting traffic, since the ping will always source from the outside.  Unfortunately I don't have any layer 3 switches sitting behind it to force the sla source to be a LAN IP.   As for the vpn-idle-timeout command, I have tried this and unfortunately it doesn't work.
Thanks.
ah ok , strange the idle didn't work was it set on both sides of the tunnel , I seen in one of the posts I was looking at that's how they got it working correctly
Unfortunately I cant really answer the NTP question my basic understanding is it uses a UDP packet to initiate to the server , if not you could try capture the traffic with wireshark it may show you exactly
