Using of BGP routing protocol
caijunjie
Hi all
I am a newbie in BGP, although i know BGP therotically. I have some curious questions
1. Can some BGP guru help to give a real life example in which a company will use BGP ?
2. With regard to AS, can someone also help to eloborate a situation in which a company need more than one AS ?
THanks in Advance
Alan
jackyoung
Level 6
Level 6
I believe the doc. in below link can help.
http://www.cisco.com/en/US/tech/tk365/tk80/tsd_technology_support_sub-protocol_home.html
Please do some research and there are lots of information in the Internet.
Some company have Internet access may use BGP, the service provider may use more than one AS. It really depends on requirement and hard to tell.
Hope this helps.
Thanks for the info
Wilson Samuel
Level 7
Level 7
Since we use BGP extensively on our Regional and Branch Offices across the world. I can surely say that we find BGP more suitable than other Routing Protocols because of the flexibility to modify how the Routes Selection and/or Route Advertisments would take place.
The PBR in BGP could be achieved through following ways:-
1.AS Path Access-List
2.Prefix List
3.Distribute List
4.Route Maps
Which gets extensively flexible when combined with the combinations of the BGP Attribs.
2. You need to use multiple AS whenever you want the Policies of the BGP to be in effect for a particular region or to a group of routers and require another set of Attribs for a different region.
I have tried to answer your queries in the respect, however please feel free to revert back in case you want more info.
Hope it helps.
Kind Regards,
Wilson Samuel
PS: Please rate if it helps.
