Using RIP in Framerelay switch
raja Saravanan
Can we enable RIP in the router which is used as frame relay switch, please help me amend the configuration, Consider below scenario
Router A is frame-relay switch and is also connected to LAN segment 10.10.10.0/24
Router B is connnected to Router C via Router A using Frame-relay, further Router B has LAN segment 10.10.20.0/24 and Router C has  got LAN segment 10.10.30.0/24
Router A S0/1 ( 192.168.10.1) is connected to Router B S0/1 ( 192.168.10.5 ).
Router A S0/2 ( 192.168.10.2) is connected to Router C S0/1 ( 192.168.10.10 ).
Router B uses PVC 100 to connect to Router C.
Router C uses PVC 200 to connect to Router B.
Router A configuration :
frame-relay switching
rip version2
network 10.10.10.0
network 192.168.10.0
int s0/1
ip address 192.168.10.1 255.255.255.240
encap frame-relay
frame-relay intf-type DCE
clock rate 64000
frame-relay route 100 int s0/2 200
int s0/2
ip address 192.168.10.2 255.255.255.240
encap frame-relay
clock rate 64000
frame-relay route 200 int s0/1 100
Router B configuration :
rip version2
network 10.10.20.0
int s0/1
ip address 192.168.10.5 255.255.255.240
encap frame-relay
frame-relay map ip 192.168.10.10 100 broadcast
Router C configuration :
rip version2
network 10.10.30.0
int s0/1
encap frame-relay
frame-relay map ip 192.168.10.5 200 broadcast
3 Accepted Solutions
cadet alain
Hi raja,
I don't think that a router can act as a frame-relay switch and frame-relay DTE device on same interface but you can use back to back DTE-DTE
frame-relay switching and it will work for sure.
Here's what you've got to do:
First on A each serial interface must be in its own subnet
you must get rid of these commands: frame-relay switching in config mode and frame-relay intf-type dce in interface mode
then you must add this command on each serial of every router: no keepalive ( to disable LMI as here we have no DCE side)
Important: the DLCI must be the same on each side of the serial connection
You'll have to replace your frame-relay interface-dlci commands by frame map ip commands
Don't forget no auto-summury in your rip statements.
Regards.
Hi Shaggy,
In Router A, I have configured two serial interfaces as DCE explicity
using the command " frame-relay intf-type DCE" which configuration commands imply that the interfaces will be treated as DTE.
for Frame-relay just putting the interface command encapsulation frame-relay implies it will be a DTE device as far as Frame-relay is concerned.
DLCI # are locally significant, what do you mean by " Important: the DLCI must be the same on each side of the serial connection ".
As you are not using a Frame-relay switch here and so as you enterd no keepalive command to disable LMI you have to put same DLCI on each end of the circuit.By the way DLCI can be locally or globally significant.
How the clocking happens when we configure back to back DTE connections?
The clocking has nothing to do with Frame-relay but simply which side is DCE( female serial cable) will provide clocking.
You always clock on DCE side whether you are doing HDLC, PPP or Frame-relay.
Here DTE to DTE refers to Frame-relay role of the router.
Regards.
Alain.
Talha Ansari
The port of frame-relay switch doesn't have any dlci number assigned instead it only knows the mapping of the source and destination dlci number to the respective exit port. Even if you assign an IP address on the port of a frame-relay switch the layer 2 dlci for that port is still missing. The switching of packets in frame-relay happens on the basis of dlci number.
Suppose if you assign an ip address and as well as a dlci number on the port of a frame-relay switch then that connectivity will be a point-to-point connectivity between the CE and the Frame-relay switch.... but yes in this case you can ping the port of the frame-relay switch, establish neighborships of eigrp, bgp, ospf etc with the frame-relay switch but your frame-relay switch will be actually acting as a router in this case.
Hope that helps....
6 Replies 6
cadet alain
Hi raja,
Regards.
Hi Cadetalain,
Good day!!! Hope you are doing good, thank you very much for your support, I have few more queries,
1). In Router A, I have configured two serial interfaces as DCE explicity using the command " frame-relay intf-type DCE" which configuration commands imply that the interfaces will be treated as DTE.
2).DLCI # are locally significant, what do you mean by " Important: the DLCI must be the same on each side of the serial connection ".
3). How the clocking happens when we configure back to back DTE connections?
Please help me, I am not able to logically understand the configuration corrections recommended by you. I am trying this in a LAB environment, I need to configure one router as service provider router, that's why I need to configure a frame relay-switch.
Thanks & Regards,
Shaggy
Hi Shaggy,
Regards.
Alain.
Hi Alain/Tahlan,
Thank you all for your best efforts!!!
I was confusing myself with configuring router as frame-relay switch ( and advertise routes in the same router using RIP, including interfaces configured for frame-relay switching ) and connecting routers back to back using frame-relay.
Frame-Relay Switch:
The frame-relay switch does address translation in the sense, it changes the DLCI# and forwards the frame to the correct router based on the mapping created on it.
Frame-relay does not support broad cast by defaullt, so we use the keyword " Broad cast " in the frame-relay map command.
Inverse ARP helps the routers connected to the frame-relay network to dynamically map the VC to the corresponding remote-sites.
Configuring router as frame-relay switch:
Suppose I have 3 routers A,B & C connected , with router A configured as frame-relay switch, what will happen if I enable RIP in router A to advertise its routes ( LAN segment & the frame-relay interfaces ) to router B & C.
Connecting Routers back to back using frame-relay:
How the DLCI # will be changed, when frame travels from Router A to B over frame-relay, here we dont have a frame-relay switch.
What is the role of Inverse ARP ?
Talha Ansari
Hope that helps....
Hi Alain/Tahlan,
Frame-Relay Switch:
