V.35 on 2911 router
Maria1980a
I need a interface v.35 on 2911 router, but it does not have WIC slot, it has EHWIC. Could some one told me if there are a card with V.35 interface that I can install in this model of router?
Thanks in advance
Reza Sharifi
The 2911 uses a HWIC T1/Serial card.  They new ones are call "Cisco Smart Serial connector"  It is 26 Pin type connector, and it supports up to 8Mb.
Have a look at this link for more details:
http://www.cisco.com/en/US/docs/routers/access/hardware/notes/marcabl.html#wp40244
Reza
Phillip Remaker
You just need an Serial WIC card
LIke
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/ser_hwic.html#wp1040370
and then the appropriate matched cable to attach to V.35.
Cisco makes a universial serial interface in a large (60 pin) or small (26 pin) format, which saves real estate on the hardware, and then the cable converts it to the appropriate connector.
