Value of ebgp-multihop ?
sang20319951
What is the value default  of ebgp-multihop if  admin no configure then command in the graphic ?
Mark Malone
You use ebgp multihop so the loopbacks can form the EBGP neighbour relationship rather than the physical interface's , without the multihop statement it wont form
Mark Malone
I see , Thank you !
No problem this doc shows you some examples and why its also used in EBGP
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13751-23.html
