09-25-2013 06:08 AM - edited 03-04-2019 09:08 PM
Hello, we have HQ with 5 remote sites and videoconference on our old Polycom videoconference bridge worked fine. The new RMX Polycom videoconference bridge sends bursts up to 80% of it's configured bandwidth and it's creating video issues (blocks on the TV screen).
The new Polycom bridge is configured to do HD using H264 high profile @ 512 kilobits per seconds.
What is the uptimum VBR-NRT values for videoconferencing? Our WAN provider is suggesting vbr-nrt 2442 2442 1 but that does not seem right for a T1.
CURRENT: vbr-nrt 1792 1792 1
TEST: vbr-nrt 1792 1692 100 (IT'S BETTER BUT STILL NOT ACCEPTABLE)
configs:
HQROUTER3725-OC3>
class-map match-all llq-video
match access-group 101
policy-map llq
class llq-video
priority 768
interface ATM1/0
description SIP ID XXXXXX/000036/UCN/001
mtu 1500
no ip address
atm ilmi-keepalive
pvc 0/16 ilmi
ilmi manage
interface ATM1/0.101 point-to-point
description 1536K circuit ID JXXXXXXXXXX
ip address X.X.X.X 255.255.255.252
no ip mroute-cache
pvc 1/136
vbr-nrt 1792 1792 1
encapsulation aal5snap
service-policy output llq
interface ATM1/0.102 point-to-point
description 1536K circuit ID XXXXXXXXX
no ip mroute-cache
pvc 1/102
vbr-nrt 1792 1792 1
interface ATM1/0.103 point-to-point
no ip mroute-cache
pvc llq 1/103
vbr-nrt 1792 1792 1
interface ATM1/0.104 point-to-point
no ip mroute-cache
pvc 1/104
vbr-nrt 1792 1792 1
interface ATM1/0.105 point-to-point
no ip mroute-cache
pvc llq-wpg 1/137
REMOTEROUTER1721-T1>
class-map match-all video
policy-map videoqos
class video
priority 768
interface Serial0/0
description Allstream SIP ID 08/XXXXXXXXX/UCN/001 - 1536K
bandwidth 1536
no ip address
encapsulation frame-relay
ip route-cache flow
no ip mroute-cache
no fair-queue
frame-relay traffic-shaping
interface Serial0/0.19 point-to-point
description 1536K PVC WPG to Ottawa - IP
bandwidth 1536
ip nbar protocol-discovery
ip pim dense-mode
snmp trap link-status
frame-relay class cirb
frame-relay interface-dlci 23 IETF
map-class frame-relay cirb
frame-relay cir 1536000
frame-relay mincir 1536000
service-policy output videoqos
09-25-2013 10:48 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If your video improved when you set a lower SCR, I would suspect the ATM PVC is overrunning the frame-relay T1. Once again set PCR and SCR to same values, but try other lower values (perhaps in 50K increments). Unfortunately as ATM overhead varies per packet, there's no 1:1 conversion.
What you can also try is reducing hardware FIFO queues, both on the ATM and frame-relay interfaces. Set smaller or minimum tx-ring-limits.
Also on the frame-relay size, don't muck with CIR shaping; just use full interface bandwidth. (If CIR is a real issue, increase it so it isn't.)
Are you seeing any drops on your LLQ? If so, try increasing its bandwidth allocation.
