Hi All,
I was wondering if anyway can helpme on this one. I have a customer who has put in a new VDSL2 over POTS connection. This type of connection is over PTM.
I've never setup this type of connection before on a 887VA. I have setup ADSL connections using the ATM and a dialer interface. This configuration will not work on my new service though. I've done some research on it and it appears that I need to use the interface Ethernet 0. Is this correct? Can anyway shed some light on how to configure this.
Eoghan
Solved! Go to Solution.
Eoghan,
When you use VDSL on an 887VA you still use the RJ11 port.
However you use int E0 rather than ATM O and pppoe rather than pppoa.
You must make sure that you shut int atm0.
This config works ok in the UK on BT-Infinity
The IP address for the WAN is negotiated and the SP should give you the chap
username and password. You will also need to find out what your vlan number from
your service provider, ours is 101
Something along these lines should get you working.
int e0
no ip add
no shut
int e0.101
encap dot1q 101
pppoe enable
pppoe-client dial-pool-member 1
int am 0
shut
int dialer 1
desc *** TO MY VDSL LINE ***
mtu 1492
ip add negotiated
no ip red
nip unreach
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
encap ppp
ip tcp adjust-mss 1452
dialer pooll 1
ppp authentication pap chap ms-chap callin
ppp chap hostname XXXXXX
ppp chap password XXXXXX
ppp ipcp address accept
no cdp ena
ip route 0.0.0.0 0.0.0.0 dialer 1
int vlan 1
desc *** MY SITE LAN ***
ip address 192.168.1.1 255.255.25.0
ip nat inside
no shut
ip access-list extended MYNAT
permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list MYNAT int dialer 1 overload
You may want to add dhcp server
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp pool MY-SITE-LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server a.a.a.a b.b.b.b
I hope this helps
Alex.
Please rate useful posts.
Eoghan,
int e0
no ip add
no shut
int e0.101
encap dot1q 101
pppoe enable
int am 0
shut
int dialer 1
mtu 1492
ip add negotiated
no ip red
nip unreach
no ip proxy-arp
ip nat outside
encap ppp
dialer pooll 1
no cdp ena
int vlan 1
ip nat inside
no shut
I hope this helps
Alex.
Thanks Alex, that answers my question perfectly.
I was thinking from online sources that this was the case but really needed the confirmation. VDSL2 is a new technology to in Ireland (marketed as "e-fibre") so this is my first configuration of it.
Thanks for your help
