VERIFY CONFIGURATION XCONNECT catalyst 9300
halima
HELLO , I've configured an L2VPN point-to-point xconnect between the interfaces G1/0/13 and G1/0/11 using the following configuration
l2vpn xconnect context test
member GigabitEthernet1/0/11
member GigabitEthernet1/0/13
interface GigabitEthernet1/0/11
no switchport
no ip address
no keepalive
interface GigabitEthernet1/0/13
no switchport
no ip address
no keepalive
To test the configuration between the two interfaces, we employed VRF to emulate the routers . However, it appears that the setup is not functioning as expected. It's possible that i ve overlooked a crucial feature or configuration.
Could anyone please assist me to test the connectivity between the virtual routers ?Thank you for your support
interface GigabitEthernet1/0/10
description test-sub
no switchport
vrf forwarding bleu
ip address 10.9.9.1 255.255.255.0
interface GigabitEthernet1/0/12
no switchport
12 Replies 12
Harold Ritter
Hi @halima ,
The L2VPN xconnect context members need to be L2 ports. Please revert gi1/0/11 and gi1/0/13 to their default configuration and it should work then.
int gi1/0/11
switchport
int gi1/0/13
switchport
Hello Sir, thanks for your response i've tried your configuration but it doesn't work unfortunately is it possible that the vrf isn't associated how can i force it to pass through the 2 interfaces ? thanks for your reply
I
Hi @halima ,
Please make sure that gi1/0/11 and gi1/0/13 are still configured under "l2vpn connect context test" after applying the configuration I recommended, as this configuration will normally cause the interface to be removed.
UUT(config-xconnect)#int gi1/0/11
UUT(config-if)#switchport
%Deleting AC member of xconnect test.
Can you also provide the output for the following commands.
show ip int brief
show runn vrf
show ip route vrf bleu
show ip route vrf red
show xconnect all
halima_0-1703669854055.pnghalima_1-1703669869250.pnghalima_2-1703669887127.pnghalima_3-1703669900785.pnghalima_4-1703669946599.png
this is my the configurations i have
Hi @halima ,
Your configuration looks good. I ran a quick test with a virtual CAT9k and it works like a charm.
When you ping vrf bleu 10.9.9.2, do you see the counters incrementing on gi1/0/11?
When you ping vrf red 10.9.9.1, do you see the counters incrementing on gi1/0/13?
You probably need to double check the external connections between gi1/0/10 and gi1/0/11 and between gi1/0/12 and gi1/0/13 as well.
interworking ip  <- add this
no switchport
no switchport <- change it to Switchport as @Harold Ritter  suggest
MHM
did you try use source IP in ping command ?
try use source and check
for
interworking IP <<- did you add it ?
MHM
balaji.bandi
make interface 1/0/11 and 1/0/13 to switchport and test it.
BB
MHM
Hi @MHM Cisco World ,
This is IOS-XR configuration. The Catalyst 9300 runs IOS-XE.
Ruben Cocheno
@Harold Ritter
I hope you doing well buddy. Building up your rankings on segment routing?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Hi @Ruben Cocheno ,
I am doing well, thanks. Hope you are doing well too. Keep up the good work on the Cisco Community.
