Verify Operation of NIM-VAB-A
emuman100
I have a NIM-VAB-A that doesn't seem to be working based on the following output, but I don't have an ADSL line to test it with yet. Here is the sh cont VDSL 0/1/0 output:
Controller VDSL 0/1/0 is DOWN
Daemon Status: TRAINING
XTU-R (DS) XTU-C (US)
Chip Vendor ID: ' ' ' '
Chip Vendor Specific: 0x0000 0x0000
Chip Vendor Country: 0x0000 0x0000
Modem Vendor ID: ' ' ' '
Modem Vendor Specific: 0x0000 0x0000
Modem Vendor Country: 0x0000 0x0000
Serial Number Near:
Serial Number Far:
Modem Version Near:
Modem Version Far:
Modem Status: Idle
DSL Config Mode: ADSL2+
Trained Mode:
TC Mode: UNKNOWN
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Failed full inits: 0
Short inits: 0
Failed short inits: 0
Modem FW Version:
Modem PHY Version:
Modem PHY Source: bootflash:
Modem PHY FW Pkg: nim_vab_phy_fw_A39t_B39g1_Bond39t.pkg
Training Log : Stopped
Training Log Filename : flash:vdsllog.bin
The chip and modem vendor information is blank. Is this normal when no DSL line is connective and trained? Is my NIM-VAB-A defective?
Tha
7 Replies 7
Mark Elsen
 - Make sure to use the latest firmware available for the device. Also I would strongly advice to check if you still have issues once a dsl line gets connected.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
The NIM xDSL cards and xDSL cards of previous generations do not require a firmware file to operate, as they come with preloaded firmware. This card seems to run an embedded linux system and the firmware is the image.
The firmware I'm using with it is the latest, but you need to read the release notes as the latest version isn't always intended for your region/DSLAM, as this was the case in previous generations.
There are two types of firmware. One is "PHY" and the other is "regular" and the configuration guide really doesn't explain the difference between the two. Do you know the difference? The guide is here.
But the question is, without it trained, should it display blank chip/modem vendor IDs or is the card defective? The previous generation shows at least the downstream channel modem/chip IDs.
Thanks.
                          - Defective or nor can only be determined by doing the final test....
 M.
       Beauty and terror
      Just keep going
       No feeling is final
What I am asking is if the blank chip/modem vendor IDs without the NIM-VAB-A trained is normal behavior or not.
 - The only further argument I can make for my case, is that if you look at the examples in the manual , the Vendor ID is always displayed when the line is  up.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I was hoping someone with a NIM-VAB-A that they knew was functional can provide the output when not trained.
THE CARD OUTPUT IS CORRECT
AS IT IS NOT CONNECTED TO VDSL LINE
I HAVE THE NIM-VAB-M AND THE OUTPUT FROM IT IS AS YOURS
