Very Slow Performance
Create Share
Hi!
Can anybody check the below configuration for 1841 and see if there is some problem that is causing slowness both from inside and outside connections?
Building configuration...
Current configuration : 2784 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no logging monitor
enable password password
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp pool 0
   network 192.168.1.0 255.255.255.0
   netbios-node-type h-node
   default-router 192.168.1.2
   dns-server ISP DNS Servers
ip name-server ISP DNS Server1
ip name-server ISP DNS Server2
vpdn enable
vpdn ip udp ignore checksum
vpdn-template 1
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
username vpn password 0 password
interface FastEthernet0/0
ip address Public IP
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.2 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered FastEthernet0/1
peer default ip address pool VPN
no keepalive
ppp authentication pap chap ms-chap
ip local pool VPN 192.168.1.51 192.168.1.60
ip classless
ip route 0.0.0.0 0.0.0.0 Public IP
no ip http server
ip nat pool ovrld Public IP Public IP prefix-length 30
ip nat inside source list 102 pool ovrld overload
ip nat inside source static tcp 192.168.1.3 3389 interface FastEthernet0/0 3389
access-list 102 permit tcp 192.168.1.0 0.0.0.255 host Internet Server1 eq 3389
access-list 102 permit tcp 192.168.1.0 0.0.0.255 host E-Mail Server eq 443
control-plane
line con 0
password password
login
line aux 0
line vty 0 4
password password
login
line vty 5 15
password password
login
end
Thanks!
Timothy Stewart
Unfortunately, just looking at the config isn't going to help in determining the reason for the slowness.
Some of the easier things to check would be errors on the interfaces (speed/duplex mismatches),
cpu utilization, ping tests with various sizes to / from the router's interface addresses, etc.
Tim
