VFR Routeing between directly connected networks
brasso_42
I have a VRF which has 3 directly connected networks. Each network can route to each other, however I want X to route to Y and Z to route to Y.
How can I stop X routing to Z?
Si
Nagendra Kumar Nainar
Hi Simon,
Did I understood that you have a PE with one VRF (say TEST1) and have 3 interfaces configured as part of this VRF?. And you are looking for way to have network X allowed to Y but not to Z. Similarly Z is allowed to talk to Y but not to X?.
If so,  X, Y and Z are CE devices or is it just stub networks?.
If it is stub networks, you have to use ACL and filter the traffic inbound at interface connecting X and Y networks.
If it is CE you may try using differnet routing protocol or different process (for instance OSPF) and limit the redistribution.
HTH,
Nagendra
John Blakley
I would think you're going to want to look at import maps under the vrf. You can specify which routes you want to import into the vrf. It's basically a policy map identifying the networks you want. I haven't tested but I believe this is what you'll want.
Hth,
John
HTH, John *** Please rate all useful posts ***
Hi Simon,
HTH,
Nagendra
