VIC 3-2e/m is not working
Hi everyone
I just installed a  vic3-2e/m card in a router 3800, but leds are always orange, even though that the card recognizes it. help
NAME: "3rd generation two port EM voice interface daughtercard on Slot 2 SubSlot 0", DESCR: "3rd generation two port EM voice interface daughtercard"
PID: VIC3-2E/M         , VID: V01 , SN: FOC15016DDS
Cisco 3825 (revision 1.2) with 480255K/44032K bytes of memory.
Processor board ID FTX1447A0ZH
2 Gigabit Ethernet interfaces
3 Channelized/Clear E1/PRI ports
2 Channelized/Clear T1/PRI ports
1 Virtual Private Network (VPN) Module
12 Voice FXO interfaces
2 Voice E & M interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
126000K bytes of ATA System CompactFlash (Read/Write)
paolo bevilacqua
Probably you do not have enough DSP resources installed for the card to work and the voice-port to be configurable.
