Virtual Link issues
Daniel S.
Hi all!
I came across issue when configuring OSPFv3 and trying to set up a virtual link. Under regular OSPF, under ospf subconfiguration, I use # area ( # of transit area ) virtual-link and Router-ID of a neighbor. With OSPFv3 I got little lost.
The commands is not an option, even under the address family subconfiguration. After research I found there is a need to configure following : #ipv6 router ospf (instance number), and then area ( # of transit area ) virtual-link and Router-ID of a neighbor, the virtual link doesnt come up and I cant find an answer.
I am attaching config from R2 and R4, thank you in advance for taking time to have a look on my issue. Not sure what am I doing wrong.
R2(config)# do sh run
Building configuration...
Current configuration : 3308 bytes
! Last configuration change at 20:52:26 UTC Thu Feb 3 2022
version 15.9
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
ipv6 unicast-routing
ipv6 cef
redundancy
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 31.0.0.1 255.255.255.252
duplex auto
speed auto
media-type rj45
ipv6 address 31::1/64
ospfv3 100 ipv6 area 20
ospfv3 100 ipv4 area 20
interface GigabitEthernet0/2
ip address 51.0.0.1 255.255.255.252
duplex auto
speed auto
media-type rj45
ipv6 address 51::1/64
ospfv3 100 ipv6 area 30
ospfv3 100 ipv4 area 30
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospfv3 100
router-id 2.2.2.2
address-family ipv4 unicast
exit-address-family
address-family ipv6 unicast
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ipv6 router ospf 1
area 20 virtual-link 4.4.4.4
R4#show run
Current configuration : 3391 bytes
! Last configuration change at 21:02:01 UTC Thu Feb 3 2022
version 15.9
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
ipv6 cef
redundancy
ip address 41.0.0.2 255.255.255.252
duplex auto
speed auto
media-type rj45
ipv6 address 42::2/64
ospfv3 100 ipv6 area 10
ospfv3 100 ipv4 area 10
ip address 31.0.0.2 255.255.255.252
duplex auto
speed auto
media-type rj45
ipv6 address 31::2/64
ip address 21.0.0.1 255.255.255.252
duplex auto
speed auto
media-type rj45
ipv6 address 21::1/64
ospfv3 100 ipv6 area 0
ospfv3 100 ipv4 area 0
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospfv3 100
router-id 4.4.4.4
exit-address-family
exit-address-family
no ip http server
ipv6 router ospf 1
area 20 virtual-link 2.2.2.2
3 Accepted Solutions
Georg Pauwen
I don't think configuring the VL under the IPv6 address family works at all. It needs to be configured under the IPv4 address family.
I recreated your setup in a lab and added the virtual links under the IPv6 address family of ospfv3 100. That might be the problem: you are creating a new process (1) which is not configured anywhere.
With the below config (addition marked in bold) the VL came up right away:
version 15.9
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
ipv6 cef
redundancy
no ip address
shutdown
duplex auto
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospfv3 100
router-id 2.2.2.2
exit-address-family
--> area 20 virtual-link 4.4.4.4
exit-address-family
no ip http server
R4#show run
version 15.9
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
ipv6 cef
redundancy
duplex auto
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospfv3 100
router-id 4.4.4.4
exit-address-family
--> area 20 virtual-link 2.2.2.2
exit-address-family
no ip http server
Georg,
It wont work with OSPFv3 the ipv4. Found it.
OSPFv3 control packets sent over a virtual link are IPv6 packets and may traverse multiple hops. Therefore, there MUST be a global IPv6 address associated with the virtual link so that OSPFv3 control packets are forwarded correctly by the intermediate hops between virtual link endpoints. Although this requirement can be satisfied in IPv6 unicast AFs, it will not function in other AFs as there will not be a routable global IPv6 address or forwarding path. Therefore, virtual links are not supported in AFs other than IPv6 unicast.
Thank you for your help.
Daniel.
6 Replies 6
Georg Pauwen
Hi Georg,
I have tried to do that but that does not work as well.
version 15.9
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
ipv6 cef
redundancy
no ip address
shutdown
duplex auto
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospfv3 100
router-id 2.2.2.2
exit-address-family
exit-address-family
no ip http server
R4#show run
version 15.9
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
ipv6 cef
redundancy
duplex auto
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospfv3 100
router-id 4.4.4.4
exit-address-family
exit-address-family
no ip http server
Hi Georg,
Once again thank you for your help.
That works absolutely fine. However ipv4 does not work and have tried under the address family, outside of address family, tried multiple things but no luck. Are we only able to create virtual link for ipv6? I did some research but so far no luck to find the solution, or just an explanation.
Daniel.
Georg,
Daniel.
good find ! Thanks for sharing, that is useful information !
