05-21-2022 02:16 AM
I have 4 sites as seen above. Each site has the same VLANs A,B,C and D. I would like to bridge these vlans across all sites so that each of the VLANs appear as a single bridge domain across all 4 sites. I have explored the possibility of using L2TP to achieve this, but it seems like it is only good between 2 sites.
Is there any way I can achieve this using L2TP, or is there any better solution to achieve my intended outcome?
Thanks.
Solved! Go to Solution.
05-21-2022 08:01 AM - edited 05-21-2022 05:48 PM
Just one thing in my mind,
Config gre and run mpls over it and this give you choice to run vpls even over IP core SP.
05-21-2022 03:07 AM
05-21-2022 07:05 AM
VPLS what you need IF they are in different Site
VXLAN IF they are in same Site.
05-21-2022 07:29 AM
I was considering that as an option as well. What if my internet backbone is not MPLS? Would it be possible to run VPLS over a fully meshed IPSec/GRE tunnels between the sites?
