VLAN Config on a Cisco SG200-50P
I am trying to setup a VLAN on my Cisco switch. I have absolutely no exposure to setting up VLANS before and feel completely out of my depth here, please help me !!! :)
I want ports 1 through 43 to appear as one network so all devices connected to any of these ports can see each other (In other words, working as a normal switch)
But on ports 44 though 48 is where I want to create the VLAN, and those five ports to work almost as an independent switch, so they see none of the devices in patched into ports 1-43, but they do see any devices patched into ports 44-48.
And also vice versa, that none of the devices patched into 1 - 43 see none of the devices patched into ports 44-48.
Do I need to setup 2 VLAN's, or just 1? Do I have the ports configured as Access or Trunk, do I need to exclude or forbid any ports on any VLAN's.
Any help would be greatly appreciated.
Mark Painting
mkazam001
Level 3
Level 3
to segregate traffic at layer 2 you need vlans
so 2 vlans in your case - if ports are connected to end users then configure as access ports
to connect to another switch - normally use a trunk
regards, mk
please rate if helpful or solved :)
fbabashahi
the default vlan in switch is vlan 1 , and it means in packets on trunk ports there is no vlan exist because it is default traffic , it is better for you to create 2 vlans to seperate traffics , and for ports that does not exist in these vlans for security has been suggested that these port mode change to access and for better, assign to a vlan that there is not any traffic eg: vlan 2,3 for your traffic and vlan 4 for unused ports
Good luck
