What is the recommended/suggested Cisco Spoke router for a DMVPN environment
Koushik147
In an Environment like up to 80 Spoke routers and a one GIG bandwidth of WAN link what would be the recommended router for this configuration, currently using Cisco 1710 routers as the spoke and 2951 series as HUB.
Deepak Kumar
You can go with 4000 Series router. Here is a compare sheet for the same.
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
According the WAN throughput/performance requirement, You can use ISR G2 and ISR 4000 series router.
Go through the below link to compare the WAN throughput/performance of the routers.
https://supportforums.cisco.com/legacyfs/online/legacy/7/1/5/15373517-white_paper_c11_595485.pdf
https://www.cisco.com/c/dam/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/miercom-isr4k-report.pdf
Spooster IT Services Team
