VLAN configuration problem.
reimpsel
Hei guys
As you see on the screen i built an network with 3 different vlans (HR, IT, Sales)
IT & HR VLANs works fine.
Problem is with Sales vlan (VLAN 30) PC5 wont get an IP address from VLAN30 if activating DHCP in NIC
I cant recall whats the problem with it. It is configurated same as both working VLANS (obviously with different subnet)
zip file with .pkt is added in attachment.
2 Accepted Solutions
@reimpsel
 There is a typo on the vlan 30 configuration
interface Vlan30
mac-address 00d0.ff5a.4603
ip address 192.138.30.1 255.255.255.0
ip helper-address 192.168.1.2
It should be
interface Vlan30
ip address 192.168.30.1 255.255.255.0
Blue_Bird
Hello reimpsel,
In Multi-Layer siwtch,
interface vlan 30
it should be
Assign correct ip address to the int vlan 30... it works.!
Best regards
******* If This Helps, Please Rate *******
@reimpsel
interface Vlan30
It should be
interface Vlan30
Thank you very much for noticing my mistake!
Blue_Bird
Hello reimpsel,
interface vlan 30
it should be
Best regards
Thank you very much!
