User No Get Privileged Access Even Though User Is Privileged 15
Iloveyou
username <user1> privilege 15 password 7 <ENCRYPTED>
line con 0
login authentication console
aaa authentication login console local
Can someone explain why user is not given privilege 15 access when he consoles in?
Is there any command to check privilege level of a user?
I am experiencing the same thing for line vty.
9 Replies 9
balaji.bandi
what is the device model and IOS code running.
do you have AAA enabled commands:
#show privilege  ( show you what level of user have access)
Example : Current privilege level is 15
basic config as below should works as expected using local authentication.
enable secret 5 $1$jtK0$yyHFcVM7xyelts1csVwrV/  ( make sure you change what ever needed)
username cisco privilege 15 secret 5 $1$0qFD$ZEMDi.7z1QTtF4EuPdlSY.  ( make sure you change what ever needed)
aaa new-model
aaa authorization config-commands
ip ssh version 2 (if you looking SSH connection)
line con 0
privilege level 15
line vty 0 - 4
privilege level 15
password cisco
transport input ssh  (only allow SSH as secure, if you like you can add telnet its not secured)
BB
Can I solve the problem without putting privilege level 15 at console or line vty?
Hello
yes- Use the cfg ive posted...test again
Kind Regards
Paul
hello
try the following:
aaa new-model
aaa authorization console
aaa authorization exec console local if-authenticated
line con 0
Kind Regards
Paul
Well I want to understand. Ssh was not configured with privilege 15. But my username was configured with privilege 15, so why did it not get privilege 15?
Hello
By default AAA applies the default authentication method is default, as such this would then be applied automatically to all access-lines (including) the console-  however when you specify a none default method (in your case you’ve so happened to have named it console – but it can be any name) then you need to specify that specific method name (authentication & authorisation) to the access line(s) specifically
Edited- this should work without any access-line configuration apart from allowing the transport method of access ssh/telnet etc..
Example2
aaa new-model
aaa authentication login default local
aaa authorization exec default local if-authenticated
Kind Regards
Paul
I don't quite get the difference between authentication and authorization.
Why was authentication initially used for username admin then later authorization was added?
Hello
AAA Authorisation allows you to work on the device, Providing you privilege to use the features you have been authorise to use, Without specifying it in a AAA method list (excluding the default) you will not be able to use the features associated to that method.
Kind Regards
Paul
@paul driver is correct
you need to config authz otherwise you need to use enable password to go to priv 15
MHM
