VLAN Deletion from C3750!!!!!!
afzaalq007
I want delete my Valan Configitarion i have several VLANs on my switches we are going to implement new plan nad for this i have to delete config........
for Example
I have Vlan 4
interface Vlan4
ip address 192.136.1.1
interface GigabitEthernet1/0/23
switchport access vlan 4
switchport mode access
switchport block multicast
switchport block unicast
no ip address
mdix auto
I want t delete all these at Once
Where ar my steps are
no switchport access vlan 4
than
Int vlan 4
no ip add
and at the end
no valn 4
all these are ok ???
after the performing above following steps Vlan 4 still exist in my runing config......
where as my Sw vtp statua is in server mode
VTP Version : 2
Configuration Revision : 5
Maximum VLANs supported locally : 1005
Number of existing VLANs : 8
VTP Operating Mode : Server
VTP Domain Name :
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x63 0xB9 0xEC 0x6B 0x48 0x40 0x0D 0x0F
Plz chk the following and suggest for the and quick solution
vijayasankar
Level 4
Level 4
You have to go to the "vlan database" privilege exec command and delete the vlan.
Have a look at the following URL.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_command_reference_chapter09186a008017f8b8.html#1031952
Hoep this helps. Rate the post if you find if usefull
-VJ
If you want to restore your factory default settings of your switch, just delete the vlan.dat file from flash. It contains all vlan information.
bye
FCS
Please rate me if I helped.
rajinikanth
Level 3
Level 3
hi,
Try to remove the interface vlan4
using cmd
no interface vlan 4
Then you wont see it in running config
and also you can remove the vlan 4 by going to the vlan database
cmd
no vlan
TO completely remove vlan info
try to delete vlan.dat file
Raj
