VLAN DHCP, some not working
m.yildiz
Dear Community,
i have the following issues,
C800 series router, 6 vlans, 4 vlans work perfectly, giving out dhcp leases, internet and so on.
But Vlan 50 and 60 no giving out dhcp adresses.
see attached show running-config
ena
C897#show running-config
Building configuration...
Current configuration : 4235 bytes
version 15.4
hostname C897
boot-start-marker
boot system flash bootflash:c800-universalk9-mz.SPA.159-3.M2.bin
boot-end-marker
enable secret 5 $1$69R8$ppwDJj5IMK0ewSH.kHIPT.
no aaa new-model
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 10.10.10.1 10.10.10.99
ip dhcp excluded-address 20.20.20.1 20.20.20.99
ip dhcp excluded-address 30.30.30.1 30.30.30.99
ip dhcp excluded-address 40.40.40.1 40.40.40.99
ip dhcp excluded-address 50.50.50.1 50.50.50.99
ip dhcp excluded-address 60.60.60.1 60.60.60.99
ip dhcp pool vlan1
network 192.168.10.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
lease 0 1
ip dhcp pool vlan10
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
lease 0 1
ip dhcp pool vlan20
network 20.20.20.0 255.255.255.0
default-router 20.20.20.1
lease 0 1
ip dhcp pool vlan30
network 30.30.30.0 255.255.255.0
lease 0 1
ip dhcp pool vlan40
network 40.0.0.0 255.0.0.0
default-router 40.40.40.1
lease 0 1
ip dhcp pool vlan50
network 50.50.50.0 255.255.255.0
default-router 50.50.50.1
lease 0 1
ip dhcp pool vlan60
network 60.60.60.0 255.255.255.0
default-router 60.60.60.1
lease 0 1
ip cef
no ipv6 cef
cts logging verbose
license udi pid C897VA-K9 sn FCZ2012902F
username Cisco privilege 15 secret 5 $1$0cBV$U.RL9goycpWEAtCRR5O8c.
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
switchport mode trunk
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Vlan10
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface Vlan20
ip address 20.20.20.1 255.255.255.0
ip nat inside
interface Vlan30
ip address 30.30.30.1 255.255.255.0
ip nat inside
interface Vlan40
ip address 40.40.40.1 255.0.0.0
ip nat inside
interface Vlan50
ip address 50.50.50.1 255.255.255.0
ip nat inside
interface Vlan60
ip address 60.60.60.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet8 overload
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
access-list 100 permit ip 20.20.20.0 0.0.0.255 any
access-list 100 permit ip 30.30.30.0 0.0.0.255 any
access-list 100 permit ip 40.0.0.0 0.255.255.255 any
access-list 100 permit ip 50.50.50.0 0.0.0.255 any
access-list 100 permit ip 60.60.60.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
vstack
line con 0
no modem enable
line aux 0
line vty 0 4
login local
transport input telnet
line vty 5 15
login local
scheduler allocate 20000 1000
end
Can anyone help me figure out the issue?
thanks for help
17 Replies 17
Hello Rick
@Richard Burts wrote:
The static default route does not have anything to do with DHCP. But the original config that was posted did not have any default route and without a default route you would not have any access to outside.
Would expect dhcp of the wan interface provide a default however this would have an admin of 254, hence why I suggested a more specific static default
Kind Regards
Paul
Hello Paul
Agree with your point.
Rick
m.yildiz
Now working for past 24h without any issues.
vlan 30, i corrected dns server too, it was working anyway.
thanks for all the support.
stay safe!
thanks again
