VLAN enabling
Mani kandan
Community Member
Hi Folks,
While try to enaling sswitching/vlan am getting error
R1(config)#vlan ?
  accounting  VLAN accounting configuration
  ifdescr     VLAN subinterface ifDescr
am using 3640 verion os on GNS 3, Kindly suggest me ...
cadet alain
try this:
enable
vlan database
vlan 10
apply
exit
show vlan-sw brief  to verify
All this will only work if you've got a NM16-ESW switching module installed in slot 1
Alain
johnlloyd_13
Level 11
Level 11
hi,
i just wanna add to what alain posted, to add the switch module in GNS3:
right click on the 3640 > configure > slots > select NM-16ESW > apply or just click OK.
also create the layer 3 SVI that will respond and route your layer 2 VLANs:
interface vlan x
ip address
