VLAN Issue for Beginner
mstory222
Community Member
I have a old Cisco 2950 with our ISP connected to port 46 with the following config:
interface FastEthernet0/46
switchport access vlan 2
switchport mode access
macro description cisco-desktop
spanning-tree portfast
spanning-tree bpduguard enabled
Somehow they are able to see VLAN1 and that switches IP address. The port disables itself with a solid amber light and this error in the logs:
00:46:22: %SPANTREE-2-BLOCK_BPDUGUARD: Received BPDU on port FastEther net0/46 with BPDU Guard enabled. Disabling port.
00:46:22: %PM-4-ERR_DISABLE: bpduguard error detected on Fa0/46, putti ng Fa0/46 in err-disable state
Am I missing a command to isolate that vlan on port 46? This vlan passes through a trunk on port 48 to a subinterface on our router.
7 Replies 7
Georg Pauwen
the BPDUs are coming from whatever is connected to FastEthernet0/46. What kind of ISP connection is this ?
Seb Rupik
Try the following:
int gi0/46
  no spanning-tree bpduguard enabled
  spanning-tree bpdufilter enabled
The ISP router is sending you BPDU packets which is causing your switch to put the switchport into an err-disabled state. Using the bpdufilter will get round this issue. You should want to drop these BPDU as you do not mange the ISP router and do not want it to affect your STP topology.
Providing the ISP is sending un-tagged frames, they will be associated with VLAN2 on the switch and be allowed to be forward up your trunk link on Gi0/48
cheers,
Seb.
I did disable portfast and bpduguard. The port was still solid amber for almost an our and then the connection magically came up. We have the scan interval set to the default 300 second refresh. I don't know what changed, maybe our ISPs equipment takes longer to reset. The connection is up so I'm happy. Thanks everyone for the replies.
Hi @mstory222
Change to resolved and rate as useful.
Thank you.
disabling spanning tree portfast might not be a good idea. I don't know what you are getting from your ISP through that link, but services such as DHCP may not work properly.
That might be the reason the link took about an hour to come up...
Hello @mstory222
As per the log you have a port with BPDU  guard enabled and this port is receiving BPDUs from the remote device.
 Remote device shouldn´t be a switch or you need to disable BPDU guard and config the port accordingly for a Switch.
-If I helped you somehow, please, rate it as useful.-
Hello
Can you explain what you mean by this?
By the way I agree with Georg enabling bgpdufilter wouldn't be a good idea unless you are positive you dont need stp as this has this feature has the same effect of not having stp.
Kind Regards
Paul
