Vlan on 1941 router: status up protocol down: unable to ping
ITfella
I am in packet Tracer trying to configure a base config on a 1941 router to a 2950 switch. The vlan status is up but the protocol is down.
The switch can not ping the router, and the router cannot ping the switch.
When looking at the logical mapping, on the switch side I have a red envelope with DTP. Any ideas how to correct this?
Current configuration : 1833 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname FL-RT01
enable secret 5 nothinggoeshere
no ip cef
no ipv6 cef
username ITfella secret 5 $1$mERr$utyMgjjmnOwvdq5cMr7z7.
license udi pid CISCO1941/K9 sn FTX1524USD0-
ip ssh version 2
no ip domain-lookup
ip domain-name AZ-RT01
spanning-tree mode pvst
interface Port-channel1
no ip address
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip classless
ip flow-export version 9
have a look at the attached project file. Basically you have two options:
Option 1 (left): add an ESW module to the router and connect the switch to the ESW module
Option 2 (right): configure a trunk between the router and the switch and put the Vlan 1 IP address of the router on the physical interface the switch is connected to
post the Packet Tracer project (.pkt) file as a zipped file...
Not solved. Here is the project. I am trying to do router6 to a switch. Adding a HWIC is not an option, as this matches what I have in my physical lab.I cannot get the router or switch to ping to one another.
Any help would be greatly appreciated!
