Unexpected exception to CPU: vector 300, PC = 0x1501C0C , LR = 0x150266C
anjelo421
Hi all,
i'm having above issue. i would like to know if some had the similar issue.
Cisco 7206VXR, 6-slot chassis
7200 Software (C7200P-ADVIPSERVICESK9-M), Version 12.4(24)T6, RELEASE SOFTWARE (fc2)
-Traceback= 0x1501C0Cz 0x150266Cz 0x323182Cz 0x32315C8z 0x32448FCz 0x3244234z 0x3243714z 0x2DB247Cz 0x2DB7F88z 0x2DA4154z 0x2DD6EB8z 0x6CBA2Cz 0x757004z
CPU Register Context:
PC = 0x01501C0C MSR = 0x00009032 CR = 0x48000022 LR = 0x0150266C
CTR = 0x00000000 XER = 0x00000000 DAR = 0x7E3F9F6F DSISR = 0x40000000
DEC = 0x00019C32 TBU = 0x0003788B TBL = 0x422E0547 MSSCR0= 0x00000000
R0 = 0x00000001 R1 = 0x094B1468 R2 = 0xFFF3B1C0 R3 = 0x0D0D0D0C
R4 = 0x0DEF5E0C R5 = 0x00000000 R6 = 0x00000000 R7 = 0xF1000000
R8 = 0x0000000C R9 = 0x7E3F9F6B R10 = 0x191F3758 R11 = 0x191F3764
R12 = 0x094B1470 R13 = 0xFFF3C560 R14 = 0x094B1568 R15 = 0x0674A8E8
R16 = 0x094B1568 R17 = 0x05EC0000 R18 = 0x0D2F91C8 R19 = 0x00000002
R20 = 0x05A60000 R21 = 0x00000001 R22 = 0x05C40000 R23 = 0x05EE6630
R24 = 0x05EE6630 R25 = 0x05EE644C R26 = 0x00000000 R27 = 0x05EE664C
R28 = 0x2151807E R29 = 0x0DEF5E00 R30 = 0x0DEF5CBC R31 = 0x05EE644C
Any indicator in the dump about the cause ? (I have NO experience in analysing cisco dumps)
Best and thanks,
Anjelo
Mark Elsen
 - Usually this due to software bug(s) , try a more recent software release for your platform, if applicable and or choose a gold-starred release.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
Sounds like a bug with the software that caused a memory leak to the "SNMP ENGINE".
NOTE:  Chassis is running on a "T" train.
sorry i didn't get that "Chassis is running on a "T" train"
hi
"T" train refers to the IOS software naming convention. You can more details about CIsco IOS naming conventions at the below link
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-release-1513t/200095-Understanding-Cisco-IOS-Naming-Conventio.html
Regarding your router reload, basically the router has crashed due to some software defects. From the crash decodes it can be seen that SNMP process was trying to access the memory during which the crash occurred.
Can you provide with the show tech of the device ?
