VLAN Port forwarding (need help)
Nayt
I've set up a small home network, home router 192.168.0.1 -> Cisco 2901 192.168.100.1 -> switch 10.10.(10-30).1 (VLAN 1,2,3) -> server (Vlan 1) (10.10.10.4)
Now i'm trying to run a service that binds on my main public ip (game server), how do i go around the port forwarding/config?
N
ADDED CONFIG
Building configuration...
Current configuration : 2009 bytes
! Last configuration change at 14:00:56 UTC Thu Apr 7 2022
version 15.4
hostname CORE-1
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXX.
no aaa new-model
ip name-server 8.8.8.8
ip name-server 4.2.2.2
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO2901/K9 sn XXXXXXXXX
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.100.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.10.10.4 28015 86.23.91.190 28015 extendable
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 10.10.10.0 255.255.255.0 192.168.100.2
ip route 10.10.20.0 255.255.255.0 192.168.100.2
ip route 10.10.30.0 255.255.255.0 192.168.100.2
access-list 1 permit 192.168.100.0 0.0.0.255
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 1 permit 10.10.20.0 0.0.0.255
access-list 1 permit 10.10.30.0 0.0.0.255
control-plane
line con 0
password XXXX
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input none
line vty 5 15
login
scheduler allocate 20000 1000
ntp server pnpntpserver.Hitronhub.home
end
you are running into a known problem with double NAT. The 'easiest' way to fix this is to put your ISP router/modem in 'bridge' mode. What brand/type/model is your ISP modem/router ?
Hello
your nat and acl statements look okay,try the following
no ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 0.0.0.0 0.0.0.0 gig0/0 dhcp
Kind Regards
Paul
Tried and did not work, I can use the DMZ feature on my hub router if that is better? (not sure where to do from there config wise) but i cannot put it in bridge mode
Hello
Can you confirm-
can you reach that specific internal host from any other internet host via tcp 28015
Also from any other host on the same internal network can you reach the internet - meaning does your dynamic pat work?
Lastly are you trying to reach that internal host from another internal  host via its natted  public ip address?
Kind Regards
Paul
